Originally Posted by JWA
You should shy away from that type as they require thru-holes drilled into the body for mounting (rocker panels, rear quarter panel & fender. Since so few pay no attention to rust prevention when modifying a vehicle this is a high-risk practice.
Additionally that type board pretty much requires additional bracing to strengthen them along their length. FWIW that type running board was and is still found on thousands of van's of all brands and descriptions.
The trick is finding a junker that has them so I can grab them cheaply. I'm not worried about the bodywork on mine; it's far from perfect and I'll take reasonable precautions when drilling.
I assume such a board already has additional bracing going to the van's frame and is not mounted just at the wheel arches. My '94, incidentally, measures about 94" from the back of the front arch to the front of the rear arch.
I'm unlikely to spend hundreds of bucks on this part of the project. Any likely looking set of boards I can get cheap is what I'll try. After all, this project has been described as low-buck and half-assed.
