Wow, last update over a year and a half, crazy! But I have a few good excuses, don't we all!?!
Anyway, let's jump into it and post some way overdue updates. After having this ambo parked for almost two years I was ready to play with it again. I decided to make it my daily driver to keep the motivation up, and it worked! First I had to replace both alternators and my vacuum pump to make it road worthy.
Then I installed a rear and a side ARB awnings (bolted right against the body), replaced the useless painted emergency lights with aluminum trims and installed a backup camera. I'll mount some backup light on those as well...
Started on the outside shower. Still need to work on the interior plumbing though.
Also started building with my way smarter than I neighbour on a Bluetooth controlled switch panel. That little stick-on panel can replace about 2' long worth or regular switches, all relay controlled. The plan is to control most of my components via the pad or my phone.
And bought myself a kool t-shirt
Cheers
David
Sent from my SGP511 using Tapatalk
