Thank you guys.
I could never imagine buying a van that wouldn't need anything (Expo ready) cause I enjoy building them as much as driving them!
So I moved on with some old and new projects
Im heading out camping for a week or so next week. Lots of dirt so deflating will be a must... So this is what I did yesterday.
Got the ARB twin from a fellow Expo member, new in box for $370. A lot of money but couldn't pass on such a good deal! I also had a tank from another application that I converted for my air system (it used to be filled with charcoal as an industrial filtration device). Only thing I need to change soon is to add an extra outlet for drain but in the meantime it works.
I mounted the compressor upside down in front of the rear passenger wheel and the tank along the frame. It's well protected there. I didn't like the filters out in the elements so I put some extensions and the filters are now by the propane compartment along with the air hose connection. Turned out great!
One weird thing is if I keep the compressor switched on the fan runs nonstop. Not a big deal as I just flip the dash mounted switch off when not in use but curious if this is normal?
I got more coming up, just gotta upload some pictures to make it more interesting... See you soon!
Cheers
David
Sent from my SGP511 using Tapatalk
