Old 12-27-2010, 06:37 PM   #41
bettyford's Avatar
Re: Betty White!!
Here we go
trying to line it up right is the hardest part. We you are by yourself at least.
once you get the marks right tape it off
Then take a deep breath and go for it
Going where most dont
"one day at a time"
Old 12-27-2010, 06:40 PM   #42
bettyford's Avatar
Re: Betty White!!
Note the burn marks on my blanket over the seats
I tack welded the cross ribs to the roof skin I didnt last time and wish I had super strong.
"one day at a time"
Old 12-27-2010, 06:49 PM   #43
bettyford's Avatar
Re: Betty White!!
I know the welds aren't pretty but it will all be covered and they work.
After filing off the extra swag I set the top back up and start screwing it down
Getting the front struts in the right place takes a little work. They have to be just right to make the canvas tight but if they are not right it will not close flush to the roof.
"one day at a time"
Old 12-27-2010, 06:53 PM   #44
bettyford's Avatar
Re: Betty White!!
I removed the rear struts I just dont like them to heavy and a pain in the A#s to deal with. not sure what im going to do yet.
Screw down the sides.
hope this helps if you thinking of doing this.
The next step is going to be trimming out the cuts and doing the finish work to make it look nice. Also thinking on what to use as struts in the rear for now 2x4s work.
Ron
"one day at a time"
Old 12-27-2010, 07:20 PM   #45
TroySmith80's Avatar
Re: Betty White!!
Lookin good!
What will you use to seal the gaps at the front and rear due to the ribbing of the van roof? Also, did the sides just luckily happen to both land on high parts? In other words, was the pop top the correct width so that the long sides of the fiberglass rest on the peaks (as opposed to valleys) of the roof? Same for the inner footprint for the tent?
Also, is the front support arm bracket just attached to the sheetmetal of the roof? Will that be strong enough if it is not at a rib? even with a roof rack and gear?
Lots of questions
For Sale: 1992 E-350 EB 4x4 High-Top
TroySmith80 is offline   Reply With Quote
Old 12-27-2010, 08:03 PM   #46
bettyford's Avatar
Re: Betty White!!
Originally Posted by TroySmith80
Lookin good!
Lots of questions
I used Marine caulking only on the tent in the front and rear the nice thing about the Chevy is they are not as deep (roof ribs) and the fiberglass top also has a rubber seal which seals the ribs as well. As for the struts it is strong enough to support them But i am going to reinforce it when I trim it out. And so far I have never had a problem with it (on my last van) even with stuff on the rack.
Ron
"one day at a time"
Old 12-30-2010, 03:10 PM   #47
Re: Betty White!! Added the Pop Top
Very cool! thanks for posting the photos of your progress.
dimension4 is offline   Reply With Quote
Old 01-11-2011, 05:59 PM   #48
well I have been looking for a top for my van. I heard that Eurovan tops have a problem with cracking. Have you heard about that? It may be just the Eurovan conversions by Winnebago that has the problem.
Old 01-11-2011, 06:11 PM   #49
bettyford's Avatar
I have never heard that but I bet if you go to GoWesty.com you can ask some VW dude. Mine comes off of the Weekender Van and its a real simple design I couldn't imagine where it would crack. Must be the big one thats not so streamlined. Would you like me to make some calls and see if i could find you one? Where do you live?
Ron
"one day at a time"
Old 01-11-2011, 10:59 PM   #50
I'm about an hour south of Reno, NV. I found a place that has one up in Reno. After I talked to them again they said the Weekender is from Germany and is a good top that doesn't crack but the Eurovan camper van is a conversion done by Winnebago and that is the one that cracks. The Eurovan camper from Winnebago has the luggage rack as part of the pop top. They like the older Westfalia top from the Vanagon as well but I think the Weekender is a better top for me because its a little thinner profile and I believe it is longer as well.
The Beast
IcyDeathPunch
Rex
Tomboy
