Old 09-09-2015, 01:50 PM   #71
rebar's Avatar
Re: Dawn Patrol Build
Nice build!
Your motorcycle carrier lift caught my eye as I cant do ramps alone. Id like to tow a camper and haul a dirt bike. Any suggestions on how I do both?
Thanks!
1995 E350 cummins 6bt/nv4500, 24' surv toyhauler, DRZ400s
rebar is offline   Reply With Quote
Old 09-16-2015, 07:05 PM   #72
Gatorbait's Avatar
So I hit a snag with the brake calipers not releasing. Flushed the brake fluid and found some crap so we were hoping that would solve the problem. Test driving it discovered that the brake booster wasn't properly working either. After inspection the master cylinder was leaking too so I just replaced all that shit. While I was troubleshooting that I found that the alternator was going bad. So I replaced that too. Might as well get it all out of the way now before I leave. Well we ****ed up trying to rush at the end of the day and didn't realize the pulley for the belt was a smaller size on the new alternator. Driving around the next day I hear, what I thought was catching a branch or rope in my driveshaft, but the pulley cut the belt to size and shredded belt got wrapped up in ****ing EVERYTHING. Yeah that was fun. ALWAYS double check your work when you're done. I keep rushing and it keeps biting me in the ass.
If you look close, you can see the pieces of the belt wrapped around the pulley by the tensioner.
Anyway, I did make some progress...
Got the uprights and top row tacked in.
Mocked up
Had to do a lot of work around the vent. What a pain.
We tried to get it nice and close.
Then I worked on the wall and ceiling panels. All shaped, sanded, ready for lacquer.
Working nights.. between the rain and the sun I'm WAY behind schedule.
I think they turned out quite nice. It's 1/4" birch ply.
Fitting em up.
So I just used some screws in the 2x2 i had holding the floor down and where the mounts for the bed are. The wood piece at the top will hold the top of the walls and the edge of the ceiling tight. You'll see later. That's what the nuts were welded to the corners for.
So my idea was to use 2" velcro on those struts on the roof to hold up the ply that had the opposite side attached to it. This way there'd be no screws visible. I hate seeing screws. I wasn't sure if the concept was going to work, but it worked out really well actually.
Gatorbait is offline   Reply With Quote
Old 09-16-2015, 07:07 PM   #73
Gatorbait's Avatar
I cut/trimmed the plastic pieces for the B pillars to fit the wood panels and painted them black to match the carpet I installed. They turned out good enough for me to consider doing the door panels, headliner, and dash... Hmmm
The next thing I did was get the counter top. I just went for the basic home depot special. The only issue is that the backsplash was so damn tall. So I took a section out of it to gain a few more inches of cabinet space. It was actually a really painless process.
Old 09-17-2015, 07:06 AM   #74
Looks great man! I love the interior paneling, just like mine.
-Eric
2010 Chevy AWD home build
Old 09-17-2015, 08:25 PM   #75
Gatorbait's Avatar
So I started mocking up the cabinet. I made a template to match the curve of the wall panels.
Old 09-18-2015, 04:25 PM   #76
Gatorbait's Avatar
I put in the motion lights today.
Also cut the hole for the heater exhaust
Now I'm ready to sand the cabinets, lacquer them, and put it all together. I'll probably do that tomorrow morning. Today seems like a good night to go out to a bar and talk trash to FSU fans.
Old 09-21-2015, 08:50 PM   #77
Gatorbait's Avatar
so I finished all the cutting, sanding, and lacquer for the cabinet.
Plenty of room for wires and ventilation.
I used pipe insulation inbetween the panel and the window
I put down some felt to prevent splinters on the mattress.
Old 09-22-2015, 06:07 PM   #78
Gatorbait's Avatar
Finished the front piece today. Also threw up the lights under the toe-kick. I think I'm moving the toilet to the other side too. I mocked up the flooring to see how it is going to look all together.
Old 09-24-2015, 02:29 PM   #79
Gatorbait's Avatar
I put in the shelf for the table
Got the 30 Gallon water tank in too.
Floor is complete
We finally got some waves so work as been put on hold.
Old 09-26-2015, 08:43 AM   #80
Gatorbait's Avatar
So an ad popped up on CL and it was exactly what I was looking for. So I drove my ass out to orlando and picked this bad thing up. 2002 KTM 300 2 stroke. It came with brand new road and knobby tires, brand new helmet, new gloves, racing gas tank, and all the original paperwork. I'll get better pics tomorrow.
