Not much has happened to Elvis over the last 2 months. Work has been too busy. I'm just starting to make some progress again as I'm feeling the pressure of spring coming and I want to have this thing campable.
I put the sink cabinet in place- the doors are being worked on now. The sink will be on the right side, the porta-pot on the left. An additional shelf will go in above the p-p for t-p and such, then a drawer at the top. I changed my mind regarding the location of the sink grey water tank. Now it will live in the base of the sink cabinet because it simplifies plumbing. It also frees up space under the sofa for 2 6 gal fresh water tanks.
There is room between the cabinet and the curved van wall where I can run the supply lines from the holding tank to the sink.
Here is a shot of the drain detail- converted from 1 1/2" NPT to 3/4"NPT to a boiler drain valve, then garden hose through the floor of the van. I ordered a grey water drain fitting for the exterior lower body panel which I can connect to a garden hose to drain.
The sink is a 15"x15" stainless. after the ptrap I'll use 1 1/2" multiflex to connect to the grey water tank.
I'm also working on the electrical system. I installed a 30amp 125Volt twist lock inlet on the side of the van.
This gets wired over to the inverter charger which is not mounted yet. I just put up the backer board for the inverter charger and other electrical goodies.
Oh yeah, the terlit is a Coleman. Looks like a comfy shape compared to the smaller thetfords which are more square. it was around 60 bucks.
