Old 10-09-2016, 12:06 PM   #1
SixCardCharlie's Avatar
Even the simple stuff can't be easy
I changed my oil and as I'm pouring I hear it leaking onto the concrete.... Come to find out my oil fill tube wasn't connected to the valve cover.
Luckily a ficm and some gauges is the last to dos on the mechanical part of my build. Starting the conversion real soon!!!
SixCardCharlie is offline   Reply With Quote
Old 10-09-2016, 04:37 PM   #2
Originally Posted by SixCardCharlie View Post
I changed my oil and as I'm pouring I hear it leaking onto the concrete.... Come to find out my oil fill tube wasn't connected to the valve cover.!!!
Not as bad as forgetting to install the drain plug
Old 10-09-2016, 05:47 PM   #3
One of my bonehead moments was starting to drain oil and not realizing that I hadn't pulled the plug out of the oil drain container so the oil could go into the container. Nothing like grasping through hot oil trying to grab and remove the plug while the oil starts to overflow the container and hit the street.
Old 10-09-2016, 10:05 PM   #4
gcvt's Avatar
Reminds me of a question I never remembered to ask. Is anyone running a Fumoto valve? A search for "fumoto" brought 0 results.
Greg
New van: 2003 E250 EB10
Old 10-09-2016, 10:17 PM   #5
MadScience's Avatar
I have a Fumoto valve on my v10 and am happy with it. Long nipple, I just connect some hose and drain directly into recycle containers. Super easy on the lifted van.
I use them on other cars as well. You do give up the magnetic plug and push the drain up just a hair.
Old 10-09-2016, 10:39 PM   #6
Going to have to pick uo a fumoto valve for my next oil change. Sounds like it would be awesome to be able to just save old oil jugs and be able to start and stop to fill it directly into them.
2004 6.0 PSD
Old 10-09-2016, 11:02 PM   #7
gcvt's Avatar
Seems like they have quite a few options - long nipple, short nipple, angled nipple, no nipple?, etc. I'm interested.
Greg
Old 10-10-2016, 12:05 AM   #8
MadScience's Avatar
Don't over-think the nipple style. Even no-nipple has a plug in bit, but you then need to not loose it, so I'd stick with long or short on anything that has plenty or clearance.
I have long on the van, and short on the oil tank tank of a dry-sump car. I also have an uninstalled no-nipple one for a diesel wagon that had doesn't have a ton of ground clearance.
Also, unless you're scraping the bottom, I don't see the extra safety clip being worth much. I've not bothered on the van. The other cars have somewhat expensive engines, so they got them.
Old 10-10-2016, 07:37 AM   #9
Jsweezy's Avatar
I just throw a 5 gallon bucket under the van and pull the plug, probably the easiest oil change I've ever done.
Pulling the oil filter off is always an adventure trying not to spill the oil out of it though.
Old 10-12-2016, 08:44 AM   #10
I've done that a couple times. Maybe more but I'm not willing to put a number on it. [emoji51]
