12-01-2020, 07:23 PM
Fiberine High Top Interior Finish Options
Hello everyone!
I've been lurking here for some time and have finally started our build on a '12 E350 EB.
One of the 1st things we did was install a Fiberine 30" Super Camper High Top.
I'll most likely start a build thread but am curious to see how others have finished off the interior of the high top, specifically the reverse flange/van roof mounting section.
I'm also curious if anyone has cut back more of the reverse flange/van roof mounting section without sacrificing structural integrity.
Thanks in advance!
James
2012 Ford E350 EB
FeralOutdoorGear.com
Escape Captivity
12-01-2020, 09:08 PM
I'll be following this post with great interest.
12-02-2020, 07:55 PM
If you can picture this
bent aluminum strap 2'' wide .125 think ( Home Depot ) cut them to length and bent them in my vice... think of a # 7 top side is like 4'' long leg is like 8''. Evenly placed along double flange. This creates a top plane and a side plane at an angle. I cut ply strips for the top and wider strips for the side. I wrapped it in 4 way stretchy carpet ( speaker carpet) but same could be done with foam and fabric. Would have done that but ran out after doing walls. Not sure these pictures will really show you.
12-02-2020, 09:59 PM
Another alternative
At risk of adding ignorance to the conversation, I previously owned a 77 Chevy van with fiberglass high top that I put some time and effort into setting up before I got smart and went E-350. I ripped off the green carpet (honest) from the roof and took the van to a local auto upholstery shop. They applied a material that looked and felt like a rough fleece but they applied it with contact cement and it formed to the curves of the top very nicely. I am in San Diego and it provided reasonable insulation for heat and prevented condensation during winter camping nights. Sorry I don't know know the name of the material but I suspect the shop used it mostly for trunk lining. But for my purposes it was inexpensive and effective and available in a few colors
12-02-2020, 11:14 PM
^^^ it’s called ozite or stretch carpet.
12-03-2020, 11:27 AM
1998 E350 7.3 Hightop
12-03-2020, 11:58 AM
^^^ mind sharing what top you have?
12-03-2020, 12:07 PM
24" Fiberine Bubble Top with osb roof and side supports.
12-03-2020, 12:51 PM
They have a couple of 24” tops. Is it the transit top?
12-09-2020, 06:03 PM
Originally Posted by jimmyrig
...think of a # 7 top side is like 4'' long leg is like 8''. Evenly placed along double flange. This creates a top plane and a side plane at an angle. I cut ply strips for the top and wider strips for the side.
Thanks for the feedback everyone! This is most likely what I end up doing.
Anyone cut back more of the old roof structure to gain clearance?
2012 Ford E350 EB
Escape Captivity
