Quick update. I have the Sienna seats installed, installed 2 Vanair exhaust fans, and have most the insulation finished. Walls, floor and ceiling all have 10mm of foil backed sound deadening and vapor tape at all the seams.
Floor has 1/2 poly sheet insulation and 1/2 plywood. We have the vinyl to finish it, but I'm waiting for the walls to be finished.
Walls have 1" and 2" in places of poly board. Stuffed mineral wool in all holes and sealed with vapor tape. Sprayed all gaps with spray foam and sanded. Plus have the support rails up for the plywood walls.
Waiting for solar install to finish the ceiling. I have 3x 290w solar panels coming. Will be charging a 24v 480-720ah lithium bank. I have all the batteries already, just debating if I need them all. And I scored a deal on some charging stuff. Victron DC DC regulator to charge from alternator, a battery monitor and a battery protector. Now I just need a solar controller.
Any recommendations for a MPPT solar controller? I was debating about 3x MPT 7210a. One on each panel, or a Victron 100/30.
