Old 02-08-2023, 02:48 PM   #141
Originally Posted by Charliesmom View Post
Me too. I tried to purchase one from England, but it needs 240 V. Truma USA said that a 110 compatible unit was not available. Ironically, my wall controller states on the front, “INet X ready.”
Have you tried going back through Sportsmobile to see if they could get you the I Net X controller? You are at an advantage that it was installed by a licensed dealer.
Old 03-17-2023, 06:57 PM   #142
Finished the stove - refrigerator cabinet
After getting the stove plumbed it was time to finish the cabinet. I got some time to install middle drawer unit in stove - refrigerator cabinet.
The garbage can is the only one claimed at the moment,
On to the doors for the other cabinets.
Old 03-19-2023, 02:33 PM   #143
h.grenade's Avatar
Nice looking build! I just found the NashFuel remote too as a solution on where to put our tank. With a 6' hose it could be mounted pretty much anywhere under the van.
I think your internet solutions is really good. On our TT I had bought a omni-directional antenna that was routed to a Netgear mobile hotspot. It actually worked really well but the problem was the fixed data. $50 for 50GB. A few nights of streaming and you are done. You can add on 10GB for $10 but thats where they get you
Who are you using for ISP? Sorry if I missed it. Nomad?
h.grenade is offline   Reply With Quote
Old 03-20-2023, 11:50 AM   #144
I am just using my AT&T account at the moment, It has worked fine for the limited use lately. In the long run I will probably going in the direction of Starlink.
greg
Old 03-20-2023, 12:53 PM   #145
Why I like the Victron Cerbo
While watching some basketball over the weekend, I brought up old program that I wrote to read information from my Morningstar Tristar-60 Solar controller. This controller used Modbus-TCP as a protocol, and the great thing about the Cerbo GX is that uses Modbus-TCP. Modbus is very convenient in that you can read multiple registers at once, so it simplifies the call to the device.
So I took the old program as a starting point, and developed one for my Victron stuff. They have an excel sheet that gives you all the registers that are available , what post processing you will need to do and such, so pretty easy.
So this is my test example program ( visual studios C# program). Being that I am using pretty much all Victron or Victron supported devices they were all available. In my old Sportsmobile had to use multiple protocols to get all the similar data ( multiple serial ports, both 232 and 485, Modbus and more. Here I just used the local IP for the Cerbo, and pretty much get the data I want.
I know it may be a little overly geeky excitement, but I remember how much coding went into getting that data on my old van. Plus, it is fun to push the brain a little.
Old 03-20-2023, 02:41 PM   #146
That’s pretty impressive. I have to look at multiple apps to get most of that input. (Victron 712 BMS, Moat temp sensors, iPhone or InReach for GPS) and still use a visible line for the “Full” level on my water tank. Geek is good, but geeky excitement is great!
Scott
2019 Transit 350 HR Eco Quigley 4X4
“Vandemic”
Charliesmom is offline   Reply With Quote
Sporty
BusTalker
Margot
FCAshevlle
