Old 02-22-2015, 07:21 PM   #21
rebar's Avatar
Re: Fuel tank for a 2005 E350
Originally Posted by Sheriffdoug
Hi, put in a Titan Fuel tank where the spare tire goes, it's about 42 gallons and pumps into the main tank with a switch on the dash and has separate filler.
Then you will need a spare tire carrier, but will have over 70 gallons of fuel!
Originally Posted by 1der
Call Jake at Aerotanks in San Bernadino and get one of his 45 +/- gal diesel tanks.
Those are great options. But I don't need the extended range getting over 25 mpg.
Then again, if its prone to leak after shortening.. That's a different story.
1995 E350 cummins 6bt/nv4500, 24' surv toyhauler, DRZ400s
rebar is offline   Reply With Quote
Old 02-22-2015, 07:30 PM   #22
1der's Avatar
Hi rebar, still worth talking to jake. He has many options, knows what dims need changing to accommodate xfer case. He can also mod a clean inspected stock tank if you do not need the larger capacity. He can also add a skid plate and aux fuel supply if you need that.
Beastie 3: 2002 7.3 EB Cargo: Agile TTB, CCV Mid Top, Custom Walk Through, Lots of stuff added. BlingMyRig.com
Old 02-23-2015, 09:09 AM   #23
Chris at Ujoint can help too.
-Eric
2010 Chevy AWD home build
Old 02-23-2015, 12:43 PM   #24
JackTuppVan's Avatar
Fuel tank shortening kit. DEMONSTRATION VIDEO .begin 9.53 end 12.38
2007 E250 Super Duty cargo
1988 Toyota Van 4x4 5-spd
Old 02-23-2015, 04:23 PM   #25
What's a "TITAN" tank? Do you mean a tank for a Nissan Titan?
Old 02-23-2015, 05:17 PM   #26
"Titan" brand name is an aftermarket utility/auxiliary fuel tank . http://www.carid.com/titan-fuel-tanks/u ... 7AodNAQALA
Old 02-26-2015, 06:21 PM   #27
Ah, thank you.
Old 05-14-2015, 06:50 PM   #28
outopawn's Avatar
Missing my 46 gallon tranferflow! I can't live with my supposedly 31 gallon but can never get more than 27 gallons in Quigley cut down V10 Gas tank. I am getting know the attendants by their first name. After a few phone calls and getting "we can't sell you a tank" or "we have diesel only" comments I decided to just do it my self.
I tracked down this tank that says it came out of a 2004 5.4L ford. Not sure what it was in prior but it looks like a Triton and has fuel pump and skid plate already with it. So do you think I could mount this aft and make it work. I dont mind doing a little fabrication. How do I hook it up to the existing fuel system? It has its own pump and sending unit. Even if I had to install an A/B swith and fuel switch i wouldn't mind. any input would be great
Trying to install in 2009 EB Quigley with cut down ford factory existing fuel tank.
Thanks
Steve
2006 EB Transformer SMB 4x4 Diesel PH F/R Aluminess SOLD February 2015
2009 EB E350 V10 Quigley - Non-SMB
2005 4x4 Excursion 6.0 Diesel EB Magnaflow Superchip - Bulletproofed
outopawn is offline   Reply With Quote
Silver Streak
Glider
Beni
hildems
