Old 03-25-2012, 09:06 PM   #441
WVvan's Avatar
Re: Hal The Van
Thanks guys. A question to Mike. How big is the vent line and what kind of a fixture do you use to pass it through the side of the van?
This weekend's work of putting down vinyl squares.
Glad that's done.
Open the pod bay doors Hal.
WWW.WVBIKE.ORG
Old 03-26-2012, 02:28 PM   #442
Re: Hal The Van
Here is a picture of my sink plumbing:
Sorry for the blurry photo. The bottom right is the gray water tank.
1 1/2" plumbing. Up and out the side of the van to:
I have no idea of where to get that. Maybe an RV or boat shop?
Old 03-27-2012, 06:34 PM   #443
cygvan's Avatar
Re: Hal The Van
http://www.iboats.com/Seadog-Locker-Ven ... w_id.39709
Red Zeppelin - 2003 Chevy Express 2500 6.0L 2WD RB
cygvan is offline   Reply With Quote
Old 03-27-2012, 10:30 PM   #444
WVvan's Avatar
Re: Hal The Van
House battery frame and venting, Post 4
With the frame for the batteries done, cut a couple rectangles from a block of nylon.
Drill a hole in the nylon blocks and use them as hold downs for the batteries. I used nylon since it is nonconducting.
Upgrade the battery caps to Water Miser Vent Caps. $3.77 each. The caps are supposed to reduce the frequency of adding water to the cells along with some other features. One advantage is they have a flip top so don't have to worry about taking the caps on and off to check fluid levels.
Install the batteries and sofa-bed then take the van out for a late fall camping trip.
The wiring in this photo is of a temporary nature. I had the inverter and furnace running off the batteries without any charging wiring hooked up. Since I wasn't charging the batteries I didn't have to worry about venting.
The advantage of four batteries is that they still read 12+ volts at the end of the weekend without charging.
Back at the garage workshop build a wooden safety block for the top of the empty frame.
With those two bolts extending upward from the battery frame it would be just like me to stumble while working in the van and impale myself on them. The wooden top should prevent that. The impaling not the stumbling.
Next up build a plexiglass lid for the top of the batteries.
I built this using the same methods as when I made the lid for the previous wooden battery box.
The lid will collect for venting the hydrogen gas produced when the batteries are charging.
continued-
WWW.WVBIKE.ORG
Old 04-01-2012, 08:59 PM   #445
WVvan's Avatar
Re: Hal The Van
Yesterday a poster at RV.net wrote about the location of their external power connection and I realized it was the answer I was looking for. Was jazzed enough to make it this morning's project. All done.
Full write up eventually.
WWW.WVBIKE.ORG
Old 04-01-2012, 10:40 PM   #446
larrie's Avatar
Hal The Van
Nice location. Where did you get the connector and how many amps is it rated for?
Larrie
89 Ford 2WD penthouse
Larrie
Old 04-02-2012, 05:58 AM   #447
WVvan's Avatar
Re: Hal The Van
Marinco 150BBIW Marine On-Board Charger Inlet (15-Amp, 125-Volt, White)
Amazon has got it.
WWW.WVBIKE.ORG
Old 04-02-2012, 07:51 PM   #448
WVvan's Avatar
Re: Hal The Van
Installed led lights in the basement.
(Add your own caption)
WWW.WVBIKE.ORG
Old 04-02-2012, 08:48 PM   #449
Pntyrmvr's Avatar
Re: Hal The Van
Hi;
Very cool lights!
Is that Zeta's hiding spot after getting busted in Moab with Romney's inflatable passion pole?
Regards,
Gavin
Old 04-02-2012, 09:51 PM   #450
Hal The Van
Lololol!!!
