More dash work.
I own a ScanGauge II but have never got around to finding a permanent spot for it. Time to take the plunge. This looks like a good spot.
Make sure it's clear of the gear shift handle when in drive. Easy to see when driving. Let's put it here. There is a wire that hooks the ScanGauge to the OBDII port located below the dash. The wire can either be plugged into the back of the end of the Scangauge. To run the wire out the back I'll have to make a hole in the dash but it will be a cleaner look.
Make a small template and use pencel rubbing to copy over the socket location.
Use this to plan out the hole.
No backing out now.
Run the wire.
The gauge comes with velco strips with adhesive backing. Stick to the back of the gauge.
Stick the gauge in place.
Then fire it up.
The wire that comes with the gauge is longer than I need so roll up the extra and zip tie it under the dash. Then go for a test drive.
Looks really nice while driving except for one little problem. As you turn the steering wheel it blocks the view of the ScanGauge.
Didn't even occur to me. Maybe if I lived in someplace with flat straight roads, Kansas I'm looking at you, I might have left it be. Around these parts that's not an option.
Find a new spot I like higher up. Will have to disassemble the dash to mount it.
Looks like this hasn't been done since the van was new. I wiped out all the ductwork I could reach.
Check that there's nothing in the way on the back of the dash panel where I want to mount the Scangauge.
Do the same for the inside of the dash. No problem.
Here's the new location.
What's one more hole amount friends.
While I have the dash apart do another project. Here is a panel voltmeter I bought on ebay for around $7.
It's made to be flush mounted but there isn't enough free real estate on the dash panel. I'll have to make a case for it. Here is a sheet of shiny steel I took off of a VCR I was tearing apart. It's thin and was used like a veneer on the outside of the VCR. Thought it might come in handy so I held onto it. Make a paper template case for the voltmeter.
Use the template as a guide for cutting the steel.
The front edge of the steel has a small lip that will grab the voltmeter.
Notch the lip where I will be bending it.
Use welding pliers to make the bends.
Once the metal is bent into the box shape it's fairly sturdy.
Make the case deeper than it needs to be.
Add a sheet metal screw to hold the case closed.
Bend the extra metal from the case depth inward.
Use bolts through the back to hold it in place on the dash panel.
By removing the sheet metal screw on the side I can open up the case and slide the voltmeter in or out. Drill a hole for the voltmeter wire in the dash panel.
Button everything up.
I wired it to one of the switches on the new switch panel so I could choose to display either the van (starting) battery or the house battery's voltage.
One more thing to check. The voltage used by the voltmeter itself. I turned the voltmeter on and locked up the van.
Here it is 18 hours later. The voltage hasn't dropped at all.
One more thing. In the above photo you can see that the first hole I drilled for the Scangauge wire now has a round rocker switch in place. I had the switch on hand and it's a perfect fit. I'm sure I'll find a use for it.
