Old 07-08-2020, 10:23 AM   #1
jpau00's Avatar
Headliner panel
I am wondering what people are using as a base for their headliners. I need to put up two panels on my roof (it has two sections of different heights) and am not sure what to use. I will glue headliner fabric to them and will install LED lights. My fiberglass top isn't the strongest, so I'd like to keep the weight low. I can probably use 1/8" paneling, but is there something better?
Thanks for any suggestions!!
jpau00 is offline   Reply With Quote
Old 07-15-2020, 08:33 AM   #2
I'd use the cheapest 1/8" paneling especially it will be covered. That stuff will easily conform, is light enough for a single-handed installation and cheap enough so you save for other more "necessary" interior things.
Old 07-15-2020, 08:47 AM   #3
1der's Avatar
Check Home Depot for a 4x8 sheet of Luan in the plywood section. It is thin and strong. Can be covered w material or stained/coated to use the figure of the wood.
Or a sheet of Coroplast - white corrugated plastic could also work. Can be used as is w lighting behind, or covered w material.
3M 90 spray adhesive is good for adhering material to either.
Both materials bend a bit to conform to the curves of the roof or walls and are light weight.
Old 07-15-2020, 02:41 PM   #4
jpau00's Avatar
Thanks! I got some Luan but also found some utility plywood that was thinner and lighter. Splinters like crazy when cutting, but not bad with a router, and its covered anyway. Set up the panel today, we'll see how it mounts.
