Old 06-22-2020, 02:27 PM   #1
How does CCV lift mechanism attach to fiberglass top?
Hi all,
I have been researching the Colorado Camper Van top and the lift mechanism and I can't seem to find much information or pictures specially regarding how the lift mechanism attaches to the fiberglass top.
At one point, from what I have seen, SMB used through bolts but from photos I have see it does not appear that there are any bolts going through the fiberglass top of the CCV so I am wondering how the lift mechanism attaches if there are no through bolts.
Any pictures would be extremely helpful. I have previous read/gone through posts from a member here having a medium CCV top installed, along with other posts from members but have been unsuccessful in finding the answer to my question.
Thank you all for your time
Wisco150 is offline   Reply With Quote
Old 06-22-2020, 05:24 PM   #2
1der's Avatar
The top is attached the lifting rails by large stainless flathead screws and washers on the outside going to nuts/washers on the inside. There are three on each side.
Old 06-22-2020, 05:29 PM   #3
shenrie's Avatar
The front to back rails on mine is unistrut. It has 3 bolts per side as described by 1der. I have to tighten the nuts on the inside periodically.
Old 06-22-2020, 06:47 PM   #4
Thank you both! I appreciate it!
Old 06-22-2020, 07:46 PM   #5
Otter's Avatar
Wisco, take a look through my album. I have multiple pictures of the inside and outside of my midsize CCV top, including the bolts.
Old 06-22-2020, 08:52 PM   #6
Thank you Otter!
Old 06-22-2020, 09:26 PM   #7
Otter's Avatar
Originally Posted by Wisco150 View Post
Thank you Otter!
You’re welcome! I just added this photo of the bolt (1 of 3 on each side of the poptop) that secures the lift mechanism to the top.
Old 06-23-2020, 06:41 PM   #8
Hi Otter! Thank you for the picture! I am in the process of collecting/organizing information and notes that I have on the SMB and CCV tops with the plan to start this fall/early winter doing a home build top. I've found a local salvage yard with a fiberglass top from a early 2000's E-150 conversion van so that is what I will be starting with!
