Originally Posted by 1der
re: Gaucho aft of the Driver seat -
Swivel the Driver seat 90 degrees for an additional 19"+ added to your gaucho. This eliminates the need for a crazy long sofa dedicated to stealth sleeping. You will need a cushion to level the gaucho seat height to the driver seat height and a filler piece for inboard/center aisle sleeping position.
Our Gaucho is 54". It becomes a stealth sleeping location of over 6ft with the driver seat swiveled. As Lilnuts 2 does, we use a couple of the cushions from the CCV Pop Top bed to make for a comfortable sleeping surface.
Added benefit of Gaucho on Driver side is the views out of the side doors plus the interaction with the 180 deg swiveled Passenger seat. When not stealth sleeping, the 90 deg swiveled Driver seat makes for added seating integrated into the living area, easy access to driver footwell storage space, and overall visual opening up of the front of the van.
re Cabinets and Doors - Running a cabinet on the passenger side about 1/3rd way into the smaller 40 door is actually a very efficient use of space.
I totally agree with all the above
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
