05-12-2016, 10:52 AM
#161
Originally Posted by mgmetalworks
There are a few differences between my design and Quadvan's.
-I've pushed the axle forward 1.25". There's now a big difference in clearance between the tire and the lower rear of the fender. My tires used to lock up because they'd get stuffed into the fender around certain corners. I hated that about Quadvan's set up. I shouldn't have to cut my fender or trim the body to fit a tire on the van especially since my old tires were tiny.
As an added bonus, because of where the axle is now, I can get about .75" more bump travel than the Quadvan set up.
-The rear radius arm mount is lower, making the arm more horizontal, which in turn increases the caster (steering axis inclination). My van had 1.5 deg of caster before I started this. It wandered in the lane, return to center was sluggish and the steering felt...blah... My intent with this design is to increase caster to ~5 deg.
-The radius arm is also modified to get even more caster than is available with stock arms.
-I'm using an off-the-shelf Fox shock and Moog progressive springs. Right away I could tell a huge difference in ride quality. All of the little jarring pot holes on my street are now smooth little bumps.
-It's also obviously lifted more now too. I'm up 3"+ from where I used to be, including the change in tire diameter.
Cool, all makes sense to me.. Now you have to work on posting some better before/after photos!
05-12-2016, 05:35 PM
#162
05-12-2016, 07:06 PM
#163
05-12-2016, 07:24 PM
#164
Those pictures do it justice. Stunning.
05-12-2016, 07:30 PM
#165
That looks killer! So the for the big question, do you have an idea when your kit will be ready for public consumption? Thanks
05-12-2016, 09:18 PM
#166
Still have some things to sort out for the kit but I'll start taking orders very soon. I'm thinking maybe July-ish for first availability.
05-12-2016, 09:24 PM
#167
Perfect I'll be watching as I'm sure many others will be! thanks
05-16-2016, 05:27 AM
#168
Ditto that!
2010 Ford E350 Super Duty EB Cargo 6.0L PS
05-16-2016, 12:05 PM
#169
Looks awesome. Any concern that the added weight of the Cummins and Allison transmission will require some re-tuning of the suspension once you get the swap ready? Or is it done already and I totally missed that?
Sold 2005 E350 Chateau
05-16-2016, 01:05 PM
#170
I'll possibly have to do a spring change or add in a spacer to bring the ride height back up when the Cummins is in. The Cummins/Allison aren't much different weight-wise than a 7.3 or 6.0 drivetrain.
