01-11-2011, 02:29 PM
#41
Re: new van build
that would be interesting. Maybe you could also widen the opening. I wonder why SMB makes such a small opening
2003 Ford E350 7.3 Diesel 15 Passenger Van | CCV Pop Top | Quigley 4x4 |
01-11-2011, 03:34 PM
#42
Re: new van build
Looks awesome - nice job, dsw4x4! Very nice to have another poptop option out there. I imagine that it was a lot of hard work to get to this point, so congratulations.
Good luck with your future builds, I can't wait to see them! And sledmods: enjoy!
Mike.
01-11-2011, 03:50 PM
#43
Re: new van build
Very nice. As much as I like my SMB penthouse, if I do another van I'll be giving you a call! The big top covers the ribs in the roof and eliminates the water puddling and running down the windshield when I stop.
The wider bed is a bonus, as is the possibility of more room with the top down.
Keep up the good work.
01-11-2011, 05:23 PM
#44
Re: new van build
Maybe the wider rim left by SMB is for structural integrity?
01-11-2011, 06:06 PM
#45
Re: new van build
Plus those steel plates that hold your bed up aren't just for holding your bed up...
01-11-2011, 07:39 PM
#46
Re: new van build
so SMB adds a steel plate around the opening?
01-11-2011, 10:43 PM
#47
Re: new van build
I think it's a steel plate down each side. They claim that it is stronger when they are done then before they cut the hole (or they used to claim that, I'm not up on the current site content!)
01-12-2011, 10:22 PM
#48
Re: new van build
Thanks for nice words everyone it is much appreciated,
I can modify a smb top to make it power the cost will somewhere be some where around 1000 dollars I had a guy that was interested in having me do this a while back and I looked into it at that point in time but he disappeared and I just let it go by the wayside. As I remember looking into it, it should not be a giant undertaking to get it done, going off of the mental pictures I have from repairing SMB tops in the past.
I am not sure why smb makes the beds so small, I do know that my cuts are within the ford body builders specs, I do not cut into any of the structure of the van. leaving that extra sheet metal that smb does is only sheet metal and has no load bearing ability at all. I think that they have to put that large steel box track because the bed and lifting hardware have nothing to support it, on my tops the lifting track and hardware are welded directly to the structure steel and not the sheet metal roof for stability and strength.
https://WWW.COLORADOCAMPERVAN.COM
00 PSD EB Quigly being converted to a Colorado Camper Van top
73 ford e100 soon to be 4wd with a 4bt
72 bronco aod injected 351 4 linked arb f/r 38in swampers
72 bronco 302 c4 soon to be 4bt w/ 5speed 4 inch lift 33 swampers
81 cj 7 in pieces at the moment injected twin turbo 401
ktm 525 exc, 620sx,
62 caddy convertible waiting for me to install 2007 northstar
02-21-2011, 10:47 PM
#49
Re: new van build
Great thread Derek, thanks for documenting.
Question: how difficult is it to salvage the old high tops? I know some of those adhesives are pretty serious. Is it easy to remove the top from the donor van without damaging the fiberglass?
There is a shop near me that has an old busted up camper van out back. No windows, inside full of garbage, that kind of thing. But it has a great top on it. I'm thinking that if i wind up with a van that would fit it, i'd like to offer him a couple hundred bucks for that top, if i can get it off his van without busting it. This is a late 80s van.
02-22-2011, 08:02 AM
#50
Re: new van build
There are several ways to remove a top if it is a reverse flange you can get in between the roof and the glass with a sawzall and a sharp old steak knife or fillet knife and cut the glue. If you use two floor jacks and some 4x4s you can jack off the floor of the van pushing the the top away from the van while you cut this will give you some separation to get the blade in there to slice the glue be sure all of the screw are removed before you do this. Used tops are not usually worth more than 100 dollars especially if you the one pulling it. I would offer him 50 dollars first. Most pick and pulls I can get a top for 40 or 50 dollars because they have never sold one before. I am not sure is a 80s top will fit on a 90s roof I have not tried it or measured one to try it. i would double check that before you go through the trouble. I sort of think it will because all of the van roof builders still sell the old roofs and I cannot imagine that they have kept around those hugh molds for 20+ years for the occasional customer so I think they are interchangeable but i am not sure. Good luck with your build.
Derek
ktm 525 exc, 620sx,
