Old 05-05-2020, 05:08 PM   #1
new wheels, new tires don't fit old brakes
New here and in need of help both Sportmobile specific and general build.
Just installed new BFG AT 265,75,16s on 16" ProComp Retro 59 wheels. These were put on my 2011 E350 that had 16" steel factory wheels. The new rims are dragging on the brakes. The wheels turned without rubbing when I was installing but once i put the van down and started to drive the miserable sound of metal on metal was soon heard. I was quite positive that the wheel size and type I chose was one used on Sportmobiles and many of the E series builds I've seen.
Am I wrong and later E-series builds are using larger rims 17" plus or are rims being modified to fit? I thought this was a no brainer upgrade but its gone south.
Any help would be appreciated.
dirtfinder is offline   Reply With Quote
Old 05-05-2020, 06:09 PM   #2
1der's Avatar
Quite sure 17” rims needed for the newer vans because of the larger diameter brakes and associated pieces. SOME 16” wheels work but very few.
Bummer.
Beastie 3: 2002 7.3 EB Cargo: Agile TTB, CCV Mid Top, Custom Walk Through, Lots of stuff added. BlingMyRig.com
Old 05-05-2020, 06:27 PM   #3
BrianW's Avatar
OEM 16” wheels (steel or alloy) will work on the 2008+ brakes, but not all aftermarket ones do — as you found out, unfortunately.
Old 05-05-2020, 08:27 PM   #4
Thanks for the feedback.
I'll do some measuring for clearance on the calipers and may take a grinding wheel to them before I resort to finding new rims.
Old 05-06-2020, 11:59 AM   #5
Back space is VERY important.
Beasty Boy is offline   Reply With Quote
Old 05-06-2020, 05:24 PM   #6
I have seen a few people with this problem and a bit of grinding solved it completely.
Old 05-07-2020, 12:09 AM   #7
itnanti's Avatar
Where did you place the wheel weights for balancing? Could those be coming in contact? My tire guy had to get creative with placement for my 16” wheels on my 13 e350. I have the 69 procomps.
itnanti is offline   Reply With Quote
Old 05-10-2020, 03:36 PM   #8
So after dismounting the tires I found two issues, innermost part of rim was slightly contacting caliper and as itnanti indicated, the wheel weights were contacting the calipers or had come off and actually gotten wedged between the caliper and rim.
Used a metal file on the calipers and removed the wheel weight and all is good. I may look for a 1/4 spacer to get a bit of extra clearance but problem free on the pavement so far.
Old 05-11-2020, 11:42 AM   #9
itnanti's Avatar
Good news
