Progress from this past weekend...
Modified the cabinet for the sink, microwave and fridge. Readers with a keen eye will note the stepped front edge to maximize utilization of the space behind the driver's seat. There was no other way everything was going to fit otherwise. The cabinet is glued and screwed using PVA glue.
I ran out of contact cement when covering the first cabinet side....both sides will have green bumpy covering, as well as the two left inside compartments. The lower left compartment is for supply water jugs, and the upper left houses the rear-facing microwave.
The Fridge is the smallest Truckfridge; the TF49. I was hoping to fit the next larger sized unit in the cabinet design, but it wasn't to be........
I also installed a (project leftover) 24V fan above the fridge condenser area to assist in cooling, and as of now, I'm also planning on leaving the upper rear section of the cabinet open. Running a 24V fan at 12V provides very close to silent operation (with less starting torque and less airflow)
Finally I used some scrap cherry to construct a face frame for the cabinet. I used #0 biscuits which was a PITA, size FF would have worked better, since they are smaller. I used end nips to "downsize" the #0 biscuits.
This cabinet with any luck will also house the water pump, sink, propane/CO detector and faucet. I'm also planning on insulating the fridge with leftover denim insulation from the walls.
