The new spindle showed up, and speaking of Park bicycle tools, the headset press worked great for pressing in the spindle bearing....I also had to machine the spindle for the ABS sensor.
I cleaned up the outer wheel bearing, here is a picture of the bearing failure:
Perhaps excessive preload? It appears that once the rollers failed the inner race spun on the spindle resulting in a bunch of galling and rust colored grease.
I used a brass drift to knock out the old bearing race and attempted several methods to install the new race. Success was finally achieved with the same brass drift in the opposite direction. I also removed and repacked all the grease in the inner bearing and replaced the big seal behind the inner bearing.
So, the brake upgrade is finished (finally!...
no more smokin' hot steel chips in my shoes!). I drove it around the neighborhood getting up to about 50mph and doing some pad bedding in. Of course, I had lots of loose crap in the back of the van which is now mostly in the front of the van.
I bought new copper crush washers, caliper bolts and brake line banjo bolts from my local Ford dealer. The banjo bolts in the Chevy calipers were different and the caliper bolts were the original Ford ones but were shortened significantly.
They work fine......even with minimal bedding in I definitely have more brakes....can't wait to get more time on them.
Here is a final beauty shot of the passenger side just before installing the wheel.
If anyone is considering a brake upgrade, reach out to BajaSportsmobile/Agile offroad. They have done several upgrades already and are developing kits for various van configs. I'd like to thank BajaSportsmobile once again for graciously offering lots of advice and guidance to get this project completed.
