...got the water tank and plumbing completed......well.....almost....still need a hose and shower nozzle out of the back door.
I bought a 9 gallon tank from plastic-mart.com, and, as it turns out, this tank is made by a company called Ronco in Tustin, CA. Since I'm local I did a will call and forum member 1der (thanks Ray!) picked the tank up for me a few days ago when he came by with his rig.
I specified the tank with a 3/4" NPT fitting for the fill port, a 1/2" NPT fitting for the supply port and a 1/4" NPT fitting for the vent port on the top of the tank. The vent is 1/4" tubing routed through the floor. The fill port has a 3/4" NPT to garden hose thread adapter and a male-female garden hose ball valve and washing machine hose attached for filling; all three items picked up at Lowes.
For stealth reasons, I did not want a city water inlet on the side of the van, so to fill the tank, I connect the house garden hose to the washing machine hose (which extends past the rear doors about 2 feet) and turn on the ball valve at the tank and fill until water runs out of the vent line under the van, then close the ball valve. The tank feeds a Shur-Flo water pump which outputs to a 2 gallon accumulator tank and a 2 1/2 gallon electric water heater that's been converted to 12V.
The entire setup lives under the new upper cabinet recently built. So far, everything works great with no leaks......just have to find a decent sprayer for the outdoor rear shower. I'm plumbed for hot water only, and I've set up up the hot water heater to output at a temp that is pleasant to take a shower.
