Originally Posted by arctictraveller
Great thread with lots of good ideas. I like the drop down propane mount, to lower it you could carry a small battery powered drill, and it's usefull for a lot of other things too. What prevents the screws from loosening due to vibration?
Torque and locktite....same as a static propane tank mount.....
I'm surprised about your 12v water heater though. Seems like it will draw a lot of current so obviously you would only run it while driving, that is unless you have a monster electrical system, but I didn't read the whole thread as I'm on the road with limited internet, so perhaps you do.
I don't have a monster electrical system, so yes mostly run it when driving and maybe keep it on a bit in camp if it's already heated.....the 300W element draws about 25 amps. I need to further insulate the tank. Member 1der has a Kid solar controller...that has a nice feature that when your batteries are topped off it can divert the excess juice into a dummy load like a water heater element. I have a basic Samlex PWM controller...doing it again I would have considered the Kid Controller, and more solar panel watts.
If you are interested, here is the thread about converting the heater to 12V, with a few thermodynamic calcs, and a few thread derailments but ultimately some OK data....
http://sportsmobileforum.com/viewtopic. ... 2&start=15
Finally, I just installed a sub between the seats, but I'm a bit baffled by all the possible adjustments, care to expand a bit on your design and settings? Thanks
Are you referring to the adjustments in your head unit or power amp for subwoofer outputs?
The basic adjustment is the crossover frequency that you want the sub to stop outputting at and the main speakers to start outputting.....these don't have to be the same.....they are typically labeled LPF (low pass filter) for the sub and HPF (high pass filter) for the main speakers.
The sub setting is a low pass filter...the filter attenuates the sub output at the crossover freq....the crossover freq is not an absolute cutoff.....the sub still outputs above this freq with a slope of degrading volume, typically 6db/octave (1st order crossover) 12db/octave (2nd order), 24db/octave (4th order crossover) and so on.
The high pass filter works the same way but passes high freqs only....so the output of the main speakers will be attenuated below the crossover freq that you set at some slope...same as above depending on the order of the crossover.
For smaller subs (like 6"-8") you can choose a somewhat higher crossover point for the low pass filter like 125, 200 Hz etc.
Larger subs are typically crossed over at 63-80-100 Hz.....suit to taste...try to get a good blend of bass without the sub sticking out......volume-wise...unless you are into that sort of thing
There sometimes is a sub polarity setting...normal or reverse....again suit to taste. One of these typically provides more sub output than the other...this is sometimes used to tame room/cabinet resonance modes (bass boomyness)....and you may also have a sub output level setting....adjust this up and down to taste....it will be minimally impacted by bass/treble tone controls or other EQ settings typically.
