Old 07-24-2024, 07:01 AM   #1
dirtanddogfur's Avatar
Preferred Solar Wiring route
I am about to mount solar panels on the roof of my SMB poptop. I am wondering about the 'best' way to wire the panels.
I thought I would drill the bulkhead outside the cloth and then run the wiring under the head liner from the outside in. Then, run the wire down the existing, factory wiring thingy. My only concern is the heavy gauge of the solar wire. I am concerned it might not be clean under the headliner or it might leave a way for 'stuff' to get in.
Has anyone done this differently?
2012 E350 SMB/Quad Van
2021 Chevy Colorado ZR2 Bison
dirtanddogfur is offline   Reply With Quote
Old 07-24-2024, 08:34 AM   #2
Yes, exactly how I did mine..although I changed the plastic wire loom for a braided loom for better aesthetics and flexibility, but that's another story. You should be able to stuff two more wires in the loom.
Old 07-24-2024, 09:30 AM   #3
Cool, thanks. That is the plan, then.
Old 07-24-2024, 02:25 PM   #4
geoffff's Avatar
Glad you two are in agreement!
I'm not sure I can picture exactly what you are thinking, though. Would you be up for posting photos?
Looks like I need to do the same thing on a van in the near future.
2004 Sportsmobile RB50 4x4 (Ford V10)
2005 Sportsmobile EB50 UJoint 4x4 (Ford V10)
Old 07-24-2024, 02:48 PM   #5
Additional detail.......
Poke hole(s) for solar wires outboard of the canvas.....ie...don't drill a hole through the roof into the interior. This way if there happens to be a leak it's outside. You can do this anywhere around the perimeter of the penthouse roof although some places are better than others for wire routing depending on where your panels are mounted (fore-aft) and where your SMB wire loom is located.
My loom is rear passenger side some are front driver's side. The wires penetrate the roof roughly above the barn doors because that's what made sense for my panel location.
Mount/seal cable gland, strain reliefs etc in a watertight manner to the top of the roof and run the solar wires through the gland and roof..they are now hanging below the roof outside of the canvas.
In my case I ran the wires into the cabin between the underside of the roof and above the canvas.....once inside they are above the headliner-between headliner and the underside of the penthouse. Run the wires to the wire loom to get them "downstairs" to your solar controller.
If you leave a little bit of slack in the wires under the roof where they enter the cabin any water that could possibly get on them will drip off where they sag, ie that point is lower than where the wires slide between the canvas and the underside of the roof.
Old 07-24-2024, 11:56 PM   #6
Solar wire
Here are a couple of pictures on how the solar wires come into my 2007 RB50 E-350. The wires penetrate the roof through the Scanstrut outside the canvas. Then the wires loop back up and slip between the roof and the canvas to the inside and through the hole in the ceiling. After this the go down the drivers side door pillar behind the seat into the van interior.
Besags is offline   Reply With Quote
Old 07-25-2024, 02:53 PM   #7
geoffff's Avatar
Thank you, these details are great.
Old 07-29-2024, 07:43 AM   #8
Completed this this weekend. Pretty painless. The Scanstrut bulkhead is easy to install. Seems like a pretty good system.
Thanks for everyones help!
Old 09-13-2024, 07:31 PM   #9
Thanks, guys! This is some great information!!
~Terry
wander is offline   Reply With Quote
Old 09-16-2024, 11:37 AM   #10
I consider the way Colorado Camper Van runs the wiring to be the premier way of doing it
-Hole to exterior is in fiberglass roof, right rear corner. INSIDE the living quarters.
-Wiring is encased in a color-matched cloth sheath that contains the roof actuator wires, the wiring for the lights, the solar or any other pass-thru wiring to the roof, and the fan wires.
-Wiring collapses along with canvas when roof is collapsed.
-Only one (1) hole through anything, once the wiring is inside through the roof, it stays within the confines of the interior to its final termination point(s).
The reason I feel this is the superior way is threefold.
-the flat fiberglass roof is easier to seal a bulkhead to than the curved rear steel corner of the existing van roof
-there is no chance of the wiring becoming pinched or bound on something external to the vehicle
-there is only one entrance point (one through the fiberglass) vs two (one through the fiberglass and one through the steel). Any opportunities you have to not drill holes in something should be realized.
Big_ern_101 is offline   Reply With Quote
