I'd be real concerned about getting stuck in traffic while you are either moving extremely slowly, or in a stop-n-go scenario - heat rises!
EDIT: Obviously have no idea how much work (and cutting) it would take to complete your install, but if its not a big issue you could proceed BUT after you have it as you envisioned I would put one of those outdoor wireless Temp monitors just above your vent. Then run the Van to get everything up to operating temperature. Once you're at that point, just let the Van idle for 15-20 minutes to see how much heat bleads into that compartment (I'm assuming you are using some sort of enclosure to seal the tank from the interior).
If it proves to be too hot, plug the vent, insulate the bottom a little & convert the space to some sort of hidden on-board storage or security compartment???
