Re: Removing Spare tire mount/Rear frame cross member
But the shoes are so SHINY!
Yep, lots of room for stuff - Aft Axle Fuel Tank, Under Floor Storage Box, Coach Batteries, Water Tanks, anything if it doesn’t have negative effects on the frame or suspension.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
