Old 07-17-2020, 02:33 PM   #1
Silicone Removal from Fiberglass Pop Top
I've been very slowly working on redoing my Sportsmobile top and I've come to a portion that I'm unsure of how to tackle.
The previous owner at one time or another decided to use silicone to cover some existing fiberglass threads on the top of the SMB top. I'm trying to figure out a decent way to remove this silicone so that I may repair the fiberglass in those areas.
I'm currently trying a wire-wheel attached to a drill which is working sort of... it's mostly just smoothing out the silicone though.
I'm planning on monsterlining the entire top instead of gel-coating. Are there any solvents I could use to remove it without harming the fiberglass?
Any help is appreciated!
109703563_10158871971009767_835289487290424661_o.jpg   109731672_10158871970979767_5499564699844595000_o.jpg   109816272_10158871971304767_4315925014273125695_o.jpg   109921136_10158871971244767_2399471428784669152_o.jpg
JCrimson is offline   Reply With Quote
Old 07-17-2020, 04:49 PM   #2
This may help:
https://www.fiberglassrv.com/forums/...val-26489.html
If you want more, Google "silicone removal fiberglass rv boat" and you'll come up with a ton of suggestions.
Bob
2002 Itasca 35U Motorhome
BCam is offline   Reply With Quote
Old 07-17-2020, 05:48 PM   #3
Originally Posted by BCam View Post
This may help:
Thanks for the reply! Yes, I’ve actually already come across that thread already and have googled quite a bit.
Some said that Acetone will destroy the gelcoat which I don’t care about, but it does make me question what it will do to the fibers underneath, and I have yet to find a solution for this specific situation.
The heat gun I used previously did a fair amount of work on the larger pieces when combined with elbow grease, but I’m unsure of how interwoven the fibers and silicone are.
I suppose I’ll keep hunting.
Old 07-17-2020, 07:11 PM   #4
Acetone, used sparingly shouldn't be a problem. I used to use it on my boat as a final clean up. Used too heavily it might affect a high sheen gelcoat but shouldn't have any effect on the underlying fibers, etc. You're going to need to scrape and sand the damaged fibers anyway to get a clean substrate. It's possible you might even go all the way through, creating a hole but this isn't a problem. Fiberglass is amenable to repair.
I used to use Marine Tex for relatively small dings on my boat:
https://www.amazon.com/s?k=marine+te...sl_i0fob7grb_e
Bob
Old 07-17-2020, 07:17 PM   #5
Don't be afraid to use a Dremel tool to grind things clean. If your roof isn't too shiny, the Marine Tex repair should be enough. If it's shiny, you'll want to get a gel coat repair kit as well.
Your best bet for step-by-step instructions will be boat related sites, including Youtube videos on boat fiberglass repair. The technique will depend on if the repair is simply cosmetic or structural.
Bob
Old 07-22-2020, 01:31 AM   #6
Razor blade
Shadefromtrees@gmail.com is offline   Reply With Quote
Old 07-22-2020, 07:52 AM   #7
REF
REF's Avatar
Send a message via MSN to REF
Think a grinder with a flap disc would be too aggressive, but you can try a palm sander with 120 on it, any residual goop comes off pretty easily with goo gone and a rag. You might have to do some fiberglass patching after to make sure things are sealed up before raptor lining.
Old 07-26-2020, 08:00 PM   #8
moorefc's Avatar
When you get most of the silicone scraped off, the final sand should be with fresh, sharp sandpaper...don't smear around the remaining silicone...stuff is a mess to remove. Acetone does nothing to glass fibers, as well as cured resin. You can reglass with polyester, but epoxy is much better, whether in marinetex, or resin with fillers. You can also use seran wrap or wax paper as nice molding surfacing forms....
Sharp knives or razor blades help with the scraping....
Pac NW and warmer places
2006 E350 EB Elect Top 2WD
moorefc is offline   Reply With Quote
Old 07-28-2020, 11:09 AM   #9
Thanks for all of the replies!
I wanted to check back in, I've actually got most of the silicone off, if not all of it.
The key was a wire wheel on a drill that removed the silicone clusters pretty quickly. There is some scuffing on the fiberglass from it, but nothing too bad. I will be sanding it with a palm sander, filling the holes with fiberglass patch, and then rhinolining it.
