08-26-2013, 08:02 AM
#61
Re: SOCAL build
So are your chassis and house systems coupled at all?
If that's the case, one concern I would have is that if you were in the backcountry, and your chassis batery failed, your CB and Ham radios wouldn't work, at least not without rewiring.
Edited:
No, all 3 electrical systems separate. I would not rely on the Icom or CB for emergencies, they are more of a novelty, just enjoy listening to some chatter when I drive.
08-28-2013, 07:08 AM
#62
Re: SOCAL build
Did a leak test on the van last night. Went to a self serve power car wash and power washed around all the holes we cut in the van. Only one small leak on the big window, easily fixed. Glad I did that now I can finish up insulating.
Hoop II came in yesterday, easy install. Got these from http://www.carid.com, they sell them in a pair and individually so I bought 3 for $97.00 shipped. Easy install, took about 1.5 hrs and 2 beers to do all three.
08-30-2013, 08:31 PM
#63
Re: SOCAL build
Finally finished up the insulation last night. Caulked, Fat-Mat and insulated around all holes that I cut in the van, finished the last little spots I missed. Nice to have that done.
External battery box came in today and got a good chunk of the wire, connectors, shrink tube bought today as well.
Nice to see some of these projects coming to an end. I have one more hole to cut (shore power), finish up electrical and plumbing then off to stage 1 of the interior build.
09-03-2013, 08:26 AM
#64
Re: SOCAL build
All clips, bolts, holes etc.. line right up. Nice fit, no drilling.
09-04-2013, 07:03 AM
#65
Re: SOCAL build
8 AWG run to battery box.
09-04-2013, 07:06 AM
#66
Re: SOCAL build
Plumbing done - almost. Will wrap it up tonight and leak test it.
09-04-2013, 09:07 AM
#67
Re: SOCAL build
Nice!
Are there factory frame holes for an additional battery box on the frame ie, two boxes?
09-04-2013, 09:56 AM
#68
Re: SOCAL build
I have not looked on drivers side but the holes are already drilled in the frame on the passenger side, very easy install. I bought it from Ebay: http://www.ebay.com/itm/320625347192?it ... 60&vxp=mtr
09-04-2013, 12:02 PM
#69
Re: SOCAL build
Nice!
I mounted two on the same side but had to drill several holes. Maybe 2 or 3 holes, the rest were there. I'm almost sure there is a spot on both sides for the boxes. I wanted mine mounted in the same side.
09-05-2013, 01:05 PM
#70
Re: SOCAL build
Where did you find the black shower fixture?
Thanks,
BB
