a few more. i guess my daughter has all the wild animal photos and the good ones.
anyways. back to my projects. going to repaint my new car hauler trailer (the place did a crappy job). get new tires for it so to get rid of the brand new china bombs.
need to do a small prep job on my prerunner truck. new hiems on the steering (8 of them), then check some stress spots for cracks and fix a few little things and it will be ready for a few loca trips and a annual 5 day baja pacific side run.
next van project: finish the heat and sound deadening around this load diesel motor and driver area. same thing i did to the rear area.
then start on the roof area. remove the nice headliner, wire up the LED puck lights with the dimmer switch, install the max air fan. when they installed the high-top, they did not cut the stock roof the last 2..3 feet. so that part of the bed feels like a cave. i am thinking of cutting it back just a bit more. then make a access door to the rest for storage like whats over the front.
the motor is fine now that i have added bullet proof diesel parts. it could use a bigger oil cooler.
