Old 06-06-2022, 07:42 PM   #141
This is looking great. Thanks so much for sharing your work on this fine van.
traeshep is offline   Reply With Quote
Old 06-12-2022, 09:26 AM   #142
I also appreciate you sharing your work—Really nice job. Maybe a silly question but where does one find the flexible propane line you’re using with the 1lb bottles and is it Coleman compatible?
Chico is offline   Reply With Quote
Old 06-12-2022, 05:40 PM   #143
Thanks, the flexible hose came with the stove. It's designed to be used with either butane canisters or 1lb propane bottles. I'm sure there's something similar out there for standard camp stoves, my buddy uses 20lb tank with his camp stove usinging a hose/regulator he got off Amazon.
ibike is offline   Reply With Quote
Old 06-12-2022, 09:25 PM   #144
More stuff
I'd been brainstorming ideas for a more elegant solution for stowing my bed panels. I knew I needed a way to separate them so they wouldn't rattle and beat themselves up.
The inspiration
After taking some measurements and sketching things up I had one of the two "holders" put together. I whipped these using some leftover 1/2" plywood I had, two pieces glued and pin nailed to make them ~1" thick. I used a templating bit in the router to make the other identical.
Once again, I stopped taking pictures and plowed through the project. After cutting out the blanks, I laminated both sides with extra material I had, added a round over to both faces and added some felt inside the "fingers" to cushion the bed panels. I made a mounting plate for each half to mount to the L-track on the wall.
The "fingers" will support each panel as they're placed inside, so you can stack all three panels without having to strap one by one.
Panels stowed and tied down, I'm using some packing foam to separate the top of the panel for now. Working on a permanent solution for that.
Also picked up the big boy Exped mattress
Got some DIY bungee netting to make a place to store bedding, mattress, comforter, pillows etc. Made a little bungee hammock for the ceiling as well, all secured to L-Track pucks.
Old 06-15-2022, 08:09 PM   #145
Made it up to Flagstaff last weekend, even got a little rain.
Galley box is working out excellent.
Was heading out Sunday morning right when the Tunnel Fire started, not good….
Old 08-04-2022, 07:31 PM   #146
Water system
Got all my fresh water plumbing installed. Started with a 15 gallon internally baffled ABS tank. Took me a while to track down the right tank since my space for it was so specific.
Once the location was situated I installed the level sensor and inspection port, all siliconed in place.
I made some cleats to keep the tank located fore and aft, then screwed a pair of tie down straps to the subfloor to hold the tank down.
Next I build a small shelf out of 1/4 plywood to hold the pump and accumulator. The plywood indexes into the 8020 slot and is secured to the top of the wheel well with some industrial peel and stick velcro.
Next I began interconnecting all the plumbing. I used 1/2" pex with crimp rings, I got some 5/8" ID rubber clamps to attach the pex to the 8020 as it moves around the cabinet.
The output of the accumulator tees, one side goes directly back to the inside of the rear door for a wash port. The other goes through two 5" canister filters, particulate and then carbon. These feed a faucet on the passenger side.
After the filters, the line hits a shutoff valve inside the van, heads through the floor and under the van to a flip out faucet I located in the footwell on the passenger side.
I made a temp panel to hold the fill and wash down ports, both Aquor. I mounted the level gauge and pump switch next to that. I wanted to keep the wheel well box open for a few weeks so I could keep an eye out for leaks. Luckily after a few weeks and ~1400 miles traveling from AZ to NM, CO and back there were none.
With the Aquor ports I can use the same hose to fill the tanks as well as connect a spray nozzle and my portable propane water heater.
Old 08-04-2022, 07:34 PM   #147
One picture I forgot. This is the tank drain out the bottom of the van, I tied the tank vent in downstream from the valve. When I fill the tank I can just turn the hose on and wait for the vent to overflow out the bottom of the van. Easy way to tell its full.
Old 08-05-2022, 03:31 AM   #148
marret's Avatar
Nice, looks great. Well done.
Chris
Old 08-05-2022, 08:30 AM   #149
aarcaris's Avatar
Nice job on the plumbing! Everything looks super clean and organized.
Vandit - 2013 E250 Ground Up Build
- Full Custom DIY Interior Build
- DIY U-Joint Off Road 6" 4x4 Conversion
aarcaris is offline   Reply With Quote
Old 08-05-2022, 09:33 AM   #150
Wow, that's a great build so far. Really clean.
bisonthecruiser is offline   Reply With Quote
Queen bee
Deaner
Sporty
BusTalker
