Added some exterior lighting as well. Picked up some RGB+W weather rated LED strip, aluminum channel and diffused cover and VHB’d in to the perfectly sized channel on the bottom of my awning.
I ran a five conductor cable into the van to support all the channels of the LED strip. Used a WeatherPack connector on the roof out of view. I’m only hooking up the white and red channels for now. Both on their own dimmer inside the side door.
I also added these guys on all four corners of the rack plus one on the rear. These will be wired to the chassis battery via a homemade relay/switch panel setup I’m working on. They’ll mostly be used when setting up camp in the dark or working on repairs etc.
They match the height of the 8020 on my U-Joint roof rack PERFECTLY! I was super happy with the outcome. I got the lights from E-Trailer.com for about $30 a light. They’re bright, but not too bright. I’m a habitual flip-flop wearer and blast my toes on a rock at least once a year walking around the van in the dark. Hopefully these light will help eliminate that.
