New flooring, tracks, boxes and lids all wrapped up.
Back on interior panels, got all the roof panels upholstered and installed. 1/8” birch wrapped in 1/8” closed cell foam topped with some Sunbrella fabric.
The little black dots are l-track discs that hold up the ceiling panels.
Started wrapping all sheet metal that will be exposed in charcoal tweed. Wall panels will receive the same material.
This is looking great! Wish I would have read through this more closely before starting my walls. I went with 6mm baltic birch and now realize that the 1/8" would have been much easier to work with. I'll hopefully be moving onto fabric in the next few weeks! What glue did you use for the fabric to metal?
__________________ Vandit - 2013 E250 Ground Up Build
- Full Custom DIY Interior Build
- DIY U-Joint Off Road 6" 4x4 Conversion
Thanks. 3M spray 90 for the fabric direct to metal just out of convenience. Dep Landau through an HVLP spray gun for all the panels.
Interior panels are all wrapped and mostly complete, need to fine tune a few of the seams between panels and get more mounting hardware but the hard part is done! Next up, boxing in the electrical components around the passenger wheel well.
Interior panels are all wrapped and mostly complete, need to fine tune a few of the seams between panels and get more mounting hardware but the hard part is done! Next up, boxing in the electrical components around the passenger wheel well. Attachment 38572
That looks great man!
What did you end up doing to cover the transition from the roof to the wall?
