02-22-2023, 09:18 AM
#221
Tell us about the yellow window covers.........
Are you referring to the picture of the van in the post further up in the thread?
If it is that is actually just some of my interior lights shining through the windshield. Looking at it again it does kinda look like I have some yellow window covers on the van.
Vandit - 2013 E250 Ground Up Build- Full Custom DIY Interior Build
- DIY U-Joint Off Road 6" 4x4 Conversion
02-22-2023, 09:32 AM
#222
yup..that's crazy.
03-03-2023, 03:18 PM
#223
Vans looking awesome! Curious to hear your thoughts on the 4:88 gearing w/ the 35" tires. I've got the same powertrain as you in my van and am considering the same gear ratio when I ultimately do my 4x4 conversion.
03-03-2023, 11:53 PM
#224
Thanks, I am super happy with how it's been coming together!
I went back and forth between 4:56 and 4:88 before ordering. At the time I was still debating going 37s and Chris at U-Joints recommended the 4:88 as it's what he has on his daily (5.4L on 35s) so I figured it was a good choice for either setup, and I am glad I listened. I've been very happy with the 4:88 gearing and 35's so far. I have only done approximately 800 miles of driving since all the conversion stuff, so I don't have a lot of seat time, but so far it drives way better than it did stock. It accelerates better, RPMs are still in a good spot, climbs the mountain passes well, and MPG didn't take as big of a hit as I thought it would. If I were to do it again I would stick with the 4:88 gearing. Also, I would suggest the tune from 5star Tuning as that helped a lot too. The shift points, speedo, etc. are all spot on with that.
03-04-2023, 06:01 AM
#225
Good to hear, thanks. I’m pretty sold on 4:88 at this point. I’ve had a 5 Star tune on my van for a few years now with their basic 87 daily tune. Did they do anything special with your tune for the 4x4/bigger tires etc?
03-04-2023, 01:06 PM
#226
Honestly not entirely sure if it's different than their normal tune. Justin from U-joint said to tell them that it's a U-Joint 4x4 converted van when ordering so I did, but couldn't tell you if they adjust anything other than the gears ratio and tire size in the tune. I drove the van briefly without the tune installed and the biggest obvious things were that the shift points were way off, so it was not as smooth and the speedometer was way off. It took a couple of tweaks to the tune with 5star to get it running the way it is now, but I feel it was well worth it.
03-31-2023, 11:46 AM
#227
Update:-Since completing the interior build we have been trying to find a solution to one of one problem that we were not really expecting, which was the flooring. We love the coin flooring and have been super happy with it and would do it exactly the same way if we were to do it again, but our dog Ace is not as much of a fan of it. Something that we have noticed especially now that he's getting a little older he tends to slide around a lot on it while we are driving if he walks around. For the most part, he's good about just lying down, but there are times that he is feeling antsy and then he just can't seem to get a good grip on it. Our temporary solution was adding in a small rug which helped a lot, but that meant he really could only again stay in one spot while driving. In addition to him sliding around at times, we have also worried about if we did damage teh floor in any way it wouldn't really be an option to redo it as it runs under all the cabinets. The flooring is extremely durable but we figured there must be a good solution out there.
After some internet searches, I came across inhabit Design Works out of portland Oregon which makes custom rugs/floor mats for sprinters using a woven vinyl material. From all the reviews everyone who has them seems to love them say they help provide a softer floor, they're easy to clean, and suppose to give more grip for a dogs. So after reaching out to them to get a quote to do a custom floor mat/rug set up I decided it was worth some effort to figure out how to do it myself. Don't get me wrong I think they make a great product, but it was too steep of a price to make it worth it for us.
So I started on my search for a product that would get the job done. After some time I found 2tec2 flooring on Perfectfit's website. This product is very similar to the Chilewich material used by inhabit but was more affordable (still very pricey though). I order a sample pack just to make sure it was what we wanted and so we could see the colors in person.
The material felt very durable, easy to clean, more easily replaceable/ repairable if damaged, and seems like it will give more grip for our dog. Also due to it having a felt backer, I think it will help keep the floor a little warmer for those cold winter nights. Once we got the samples we did some tests just to make sure it would be a good fit for us. It passed our scratch test with flying colors though the grip test wasn’t 100% conclusive but it does seem like would be an improvement over the coin flooring. I was the least confident in how the material would handle a water test. For that, we first ran water over it in the sink and surprisingly it beaded right off so we took it up a notch and submerged it for a while in the sink. Unsurprisingly the felt did soak up some water but after an afternoon on a window sill in the sun, it was 100% dry! That sealed the deal for me and sent me on the next search, how to finish the edges without a sewing machine, and how to secure it in place. After thinking through multiple ideas for finishing off the edges I finally came across an idea that I liked and seemed like it would work! The plan was to use a rubber edge seal trim. This would be easy to install, easy to replace, inexpensive, and give it a clean finished look without the added cost or struggle of trying to sew through the thick material. So I ordered a bunch of different options from Amazon and started testing them out on the sample pieces. After doing a couple of tests I found our favorite one and placed an order for the material and edging. Then it was time to test how well a snap would work in the material. I ordered a cheap tool from amazon to help do that install and it worked perfectly so it was go time! I ordered all my materials and started on my template.
Test Piece Number One
The Start of The Template
Since I have toe kick lighting I decided to only use the edge trim on the outside edges to help minimize the impact on those lights. The material is still run all teh way back under the toe kicks though to help lock it into place and give it a seamless look.
Traced the template out on the backside of the material.
First Test piece in the van.
Ace approves of the floor mat
Decided to cut the outside edge after getting the inside edge all locked in.
Still pretty thin even with the rubber edge seal installed.
Was able to run it all the way up to under the front Husky floor liners.
Still might add a few snaps on the outside edge but so far it's not moving
After getting the main floor section done I had quite a bit of material left over so I went ahead and used it for the factory step locations.
Passenger side step
Driver side step
I still have a decent amount of material left over so I am going to make inserts for all the drawers in the van. I will post some more pictures once I get those done and any other added areas I may do depending on how much material I have left after those.
03-31-2023, 12:35 PM
#228
Let's say you're at the beach and you get a bunch of sand on the floor...do you think that material would hold a bunch of sand and be hard to clean out? I've only seen that material from a distance and I like the look of it but I'd like to know if clean up after a beach day is just a shop vac and a wipe down or something more involved.
03-31-2023, 12:52 PM
#229
Think it's great you're taking into account the comfort of all the family members Austin!
03-31-2023, 01:10 PM
#230
I love that carpet install, really making me think about following in your foot steps
