I had thought the spark plug problems were with older vans, but after googling it appears that the problem wasn't totally fixed until the 2008 model year. Here is what I could glean from my searches:
- Triton engines through about 2005 didn't have enough threads in the head and plugs would blow out, stripping the threads
- On Triton 3-valve engines through 2007 the plugs would tend to seize in the head, usually discovered at 100,000 miles when the plugs are supposed to be changed. I think the van has a 2-valve head?
- It isn't clear if 2-valve heads from 2005-2006 had problems
In any case if I buy the van it might be a good investment to inspect the threads and use a torque wrench to re-install, maybe every 20-30,000 miles... I'm sure the plugs are easy to access
