Originally Posted by 86Scotty
Don't even bother with them, just get out the Sawzall and cut them off. No matter how good or expensive the shocks were this is the way.
I have to chuckle just a bit having tried accessing those nuts before discovering how easy they are under the van behind the cross member. Me and a long time mobile mechanic friend tried reaching in from outside the body which proved nearly impossible. If the shocks won't be reused and are truly shot the Sawzall is by far easy enough.
Also if your existing shocks aren't similar to Bilstein those with that thin metal shell or hood over the rod would benefit from the Sawzall method.
I do find using the anti-seize on all shock stud fasteners makes removal quite a bit easier as rust doesn't form on the threads.
