Old 12-02-2022, 12:23 AM   #1
Gone Traveling
2010 Ford E-Series Van "HIGH TOP CONVERSION VAN"
2010 Ford E-Series Van "HIGH TOP CONVERSION VAN" On Ebay
https://www.ebay.com/itm/385267973231?
tomsjack is offline   Reply With Quote
Old 12-03-2022, 10:59 AM   #2
It's an E-150......interesting that the E-150 GVWR is 8600 lbs, only 200 lbs less than my 2008 E-350.
Old 12-03-2022, 11:30 AM   #3
I have an E250 with the same 8600 GVWR. I wonder how the GVWR is arrived at (springs, axle, brakes, a combination?) and why the same sub-model came off the assembly line with different ratings. Were they specifically ordered by customers that way?
N147JK is offline   Reply With Quote
Old 12-03-2022, 01:37 PM   #4
In recent years (from when the E-150's went 8 bolt lugs) I know the GVWR went up on those. They may have larger brakes than the older ones as well.
The frames of the 150/250/350 have different cross sections (section modulus) I would imagine that has some bearing as well.
If CarringB stops by I imagine he has more insight on this.....
Tags
ford e-series van
