In case anyone's in the market to buy, here's the Ebay add and some of the pictures:
This is a solid well maintained and rust free California van that will provide reliable and comfortable transportation for many years. It was built to carry two people and a large dog over desert and mountain terrain in both hot and cold weather and is a capable and cosy camper.
The vehicle is located in Southern California and available to be inspected by appointment.
Features:
Too many modifications to list but includes the following:
Agile 4X4 system with low range. Ford TTB front axle, BW1356 electric shift transfer case. 20” Fiberine high top. Aluminess front and rear bumpers and nerf bars. 33” Cooper Discoverer AT3 tires. Hydroboost brake conversion. Oversized dog enclosure with dedicated A/C system and air (Hair) filter. Fantastic fan roof vent. Upgraded seats, passenger side swivels. 10x8ft freestanding Dometic awning. Rear axle Panhard rod. Engel 43QT 12/120V refrigerator. ARB twin compressor OBA, Camera system with four cameras. Twenty gallon fresh water tank, water heater and shower. Propex 8200BTU propane heater with four gallon propane tank. Legun table with single propane burner. Twin sleeping benches with 4” foam pads. Ultragauge engine monitoring OBD reader. Class three receiver hitch with four pin trailer wiring. Front receiver hitch. Heavy duty Jensen radio with weather band and Bluetooth. Prewired for VHF radio and portable solar panels. 110V exterior shore power connection. Dimmable LED indirect cabin lighting. Red LED interior night lighting. Many spares and take-off parts and factory manuals included.
Maintenance:
Recent maintenance includes rebuilt transmission, replaced fuel pump, plugs and coil packs, all terrain tires, serpentine belt, engine oil change, heavy duty brake pads, radiator flush, brake fluid flush. Renogy 100AH house battery.
Disclaimers:
Vehicle has been used offroad and has “desert pinstriping” and minor paint scratches.
Common Econoline issue of the gas station pump shutting off when filling the fuel tank. A simple vent tube work-around has solved the problem but this may cause a trouble code to show sometimes.
Sheetmetal damage to rear PS panel from tire blowout.
Vehicle is in current use so mileage is subject to change.
GPS unit is not included in this sale.
