When checking for rust, make sure you pull up the padding in the cockpit. It's a prime area for rust. I purchased a van that I knew had some surface rust underneath and a little on the quarter panels, which didn't concern me. What I didn't know was the cockpit floor pan on the passenger side was 50% rotted out with some rot on the driver's side.
The padding that Ford used under the rubber floor gets soaked and traps moisture.
Bob
2002 Itasca 35U Motorhome
