Old 11-02-2024, 06:25 PM   #1
Send a message via ICQ to TimRiker Send a message via AIM to TimRiker Send a message via Yahoo to TimRiker Send a message via Skype™ to TimRiker
1998 5.4L 105k e250 - P0171 P0174 codes
1998 e250 Sportsmobile, penthouse, uJoint 4x4 conversion, etc. 105k miles.
Spent last week seeing sites around Utah. We had a blast. About 100 miles off-road on various trails, and 1000 miles or so total.
Picture of the trip on https://4x4tent.com/ including our first river (creek?) crossing.
On the trip home, then engine threw these codes:
  • P0171 System too Lean (Bank 1)
  • P0174 System too Lean (Bank 2)
Still drives fine, with plenty of power, etc.
I suspected the air cleaner as a lot of the off-road trails were dry and dusty. I removed, cleaned and replaced the air cleaner, and it was not nearly as dirty as I expected. It looked good.
Other posts like this one:
https://www.sportsmobileforum.com/fo...-4l-27394.html
mention replacing the forward sensors. Where are these? On the downpipes I presume? I don't know if they have been replaced, but we did just recently cross 100k miles. Also, where is the mass air sensor? Is that worth cleaning and/or replacing?
SLC 1998 e250 5.4L uJoint 4x4 Sportsmobile
TimRiker is offline   Reply With Quote
Old 11-02-2024, 06:33 PM   #2
vacuum leak. Forget what I did but forgot to reconnect a vacuum line and got similar codes, 2002 5.4L e-250
Old 11-02-2024, 06:35 PM   #3
With the engine running, I'm listening under the hood and not hearing any tell tale hissing. I've not tried opening the doghouse and listening there yet.
Old 11-02-2024, 08:55 PM   #4
Yup, exact same thing happened to me. I poked around and found a huge crack hiding down in the folds of the intake ducting. Fixed and codes never came back.
Old 11-02-2024, 10:48 PM   #5
The standard test is to spray carb cleaner and listen for a rise in RPM.
Old 11-03-2024, 08:29 AM   #6
Don't start throwing parts at it....
Just water in a spray bottle can be used for finding a vacuum leak as well, or an un-lit propane torch. The folds of the intake as @N147JK mentions are popular, as is all the plastic/rubber vacuum lines around the manifold.
kbeefy is offline   Reply With Quote
Old 11-03-2024, 03:18 PM   #7
Mikerson's Avatar
Double check around the pcv valve they tend to pop out randomly. I had the same set of codes and that was the issue.
Mikerson is offline   Reply With Quote
Sporty Spice
Tapatio
PigPen
velo47
