Old 03-03-2016, 04:53 PM   #1
2002 7.3 Won't Start
Started up and drove for about 2 hours yesterday with no problem. Did about 10 miles on dirt roads and then parked for about 3 hours. When I got back and started it up the engine just turned for a long time with nothing and then it just fired right up and we drove back home at freeway speeds for about 2 hours. No loss of power and it seemed to run fine. This morning I head back out to start the van and it won't go. It turns over endlessly but it almost seems like it's not getting fuel.
I'm just wondering where I should start and maybe the most likely cause.
CaptainVo is offline   Reply With Quote
Old 03-03-2016, 05:06 PM   #2
rallypanam's Avatar
HPOP... The injectors won't fire unless the pressure is above a certain point. If the HPOP doesn't produce that pressure, no go. There's a bunch of tests you can do (google!), as there are a handful of components that can cause the HPOP not to create enough pressure (or think that it has not created enough pressure).
Old 03-03-2016, 05:35 PM   #3
Does the tach move when cranking....no....cps
Do you have 500psi oil pressure while cranking...no...could be hpop, injector orings, low on oil... like rallypanam said above, google the possibilities
just something to start with
Old 03-03-2016, 05:46 PM   #4
Could be your TPS (Throttle Position Sensor) acting up?
Robert
Robert Britton
2000 Chateau 7.3
Chinook 4x4
robtbritn is offline   Reply With Quote
Old 03-03-2016, 05:53 PM   #5
I'll setup my scanguage later and see if I can get some readings. After the long start yesterday it ran well, whatever that means. The small oil gauge fluttered a bit before but now it's not doing anything. I'm also not getting any codes.
Old 03-03-2016, 08:30 PM   #6
Just a random guess off the top of my head... CPS.
They're known to be faulty and they're cheap and easy to replace.
ert01 is offline   Reply With Quote
Old 03-03-2016, 09:36 PM   #7
I have an extra CPS so I'll give it a try.
Old 03-04-2016, 12:29 AM   #8
rallypanam's Avatar
Yes. Sorry, that should have been my first answer. Takes 10 minutes to change and could certainly cause what you've been seeing... They often give some warning before they fail.
Old 03-04-2016, 05:03 AM   #9
10mm 1/4" socket with short extension
long flat blade screw driver
can of electrical cleaner to clean plug
Old 03-04-2016, 10:53 AM   #10
I've had CPS issues. You think you're stuck, and then they suddenly work again (for a while).
