Originally Posted by posplayr
I consider those to be nearly perfect for oil and transmission pan draining without spillage, perhaps more so the transmission due how problematic that can be to remove while still containing fluid. The 14mm x 1.5 thread pitch matches Ford's oil pan plugs. If you DIY your own oil changes in a driveway you'll appreciate being able to accurately aim the flow into a catch can or bottle.
When I install one in the transmission pan a hole is drilled as shown and a nut used as a way to secure the Quick Changer to the pan. I'll use something like JB Weld to secure it all to the pan and prevent any leaks or loosening of the fitting over time. Photo:
I install mine as shown as it becomes the lowest point of the pan when I'm doing the fluid flush in my sloped driveway. It's also a way to partially protect the fitting should ground clearance ever become a concern. Honestly it doesn't matter where its installed, anywhere in the bottom of the pan works great.
Some may find this type too costly but for what they do, that they're one time purchases AND of extremely high quality I believe they're good bargains. I believe they come with a lifetime warranty against leakage.
