Old 06-07-2022, 10:27 AM   #21
Sorry: for the oil pans with drain plug! I bought one for 25$, seems to work just fine
Old 06-07-2022, 12:05 PM   #22
They are available ranging from $7 up to what I use, all a matter of personal preference I suppose.
Old 06-07-2022, 01:22 PM   #23
Rockauto has multiple manufacturers for my 4R75E.
Even if the pan has a plug and even if it doesn't strip you still do not get the hose attachment that gives a big advantage at not getting tranny fluid all over the shop floor whereas the other does not.
Now if you screw in one of the same after-market plugs and JB weld it in and then you might have a solution that is equivalent.
Old 06-19-2022, 05:58 AM   #24
Just a follow-up sharing my Mercon V fluid test results from Blackstone Lab received recently. I'll post it inside this reply plus attach a copy in case one is more clear than the other.
I will be reducing the mileage before my next change---make it closer to the recommended 30K, maybe going no further than 40K maximum. Because I've found a somewhat "easier" way to do this it will become pretty much like an engine oil change.
MSH MBL
Skivvie
quigley
4x4Ken
