Re: Cooling system components
Just last weekend I replaced my thermostat, coolant reservoir bottle, radiator cap and fan clutch due what I thought was an overheating problem. My symptoms were coolant being expelled from what I thought was the radiator cap after a drive with A/C on during a "hot" day. As it turns out the cap wasn't holding proper pressure but more importantly the reservoir bottle had a small leak shown here:
Smart shopping found a Motorcraft YB3016 new fan clutch assembly ($85) and radiator cap ($11), reservoir bottle cheapest through dealership ($82) andNAPA t'stat ($8). FWIW NAPA had a sale on their pre-mixed green coolant for $7 a gallon--at such a good price I bought 12 for general purposes.
Changing the fan clutch was super simple but I did buy a Gear Wrench pulley holding tool---not sure this would have been so relatively easy without that tool. I did use a properly adjusted pipe wrench removing the fan clutch nut but if interested in using the correct wrench it measures nominal 36mm.
The radiator cap tested to open at about 13 lbs which seemed to warrant replacement---for $11 new OEM that's a no-brainer.
I did "test" the radiator for potential partial clogs by running a garden hose into the top opening, lower hose removed. Flow was equal going in and coming out---no apparent backing up of water in the radiator. Also no migration of coolant, ATF or engine oil which was a concern when this imagine over heating situation was first noticed.
Not sure how often the coolant bottles develop leaks but this is my first on an E-Series.
Monitoring my coolant temps via a scanner I see anywhere from 200*F to 230*F depending if A/C is running and at an idle. At freeway speeds with A/C on a hot day (90*F + and very high humidity) I hold just about 207-210*F.
The new fan clutch absolutely roars, at least 2-3x louder than the OEM part removed---this from a dead stop accelerating up through 35 MPH or so. Once speed is reached the noise subsides---oddly enough its comforting knowing the fan is moving that much air.
So just a few tidbits about these particular components---if any questions please feel free to ask!
