Originally Posted by SAMarty
The only thing that drives my wife crazy is the fan noise when the engine is above 225 deg Sounds like an airplane landing between the seats.
You definitely want that fan running, so the sound dampening suggestion is sensible advise, and an easy upgrade.
I'd also recommend installing a low temp thermostat, and run a 5-star tune that engages the fan earlier than what you're experiencing now. Having the fan start sooner really helps maintain the temperatures when climbing grades, and also on those slow crawls that annoyingly tax your temps since little air passes through the radiator at slower speeds.
