Old 04-27-2023, 06:47 PM   #1
6.0 psd p683 code
Hello Folks,
I'm getting an intermittent P-683 (Glow Plug Control Module to PCM Communication Circuit Code). I clear it and with in a few days it returns. It usually does not set the Service Engine Light. While there are a host of things things mentioned in the trouble shooting article it seems that these engines have a quite a few "common" weak points that cause issues. While probably obscure does anyone have any personal expertise with this particular code? Thanks in advance!
Pat
https://www.obd-codes.com/p0683
PatO is offline   Reply With Quote
Old 05-04-2023, 03:38 PM   #2
Most likely wiring harness issue.
cfh420 is offline   Reply With Quote
Old 05-18-2023, 08:02 PM   #3
Well the GP Control Module has been eliminated as the cause, I now have a new one. I went with the mechanic's opinion without doing any diagnostics. My bad. I guess I have a "spare" GPCM now. On to the wiring...
A Ramblin Van
truen
Rosy
Isever
