08-31-2015, 10:54 PM
#31
Re: 7.3 and Hills
4.10 here
09-01-2015, 07:12 AM
#32
Re: 7.3 and Hills
I will call today and find out and follow up. Thanks for all the great info.
TexGX
2003 7.3PSD RB50 Quigley (The Yeti)
viewtopic.php?f=10&t=13220
2006 Casita (Makes it a three bedroom 1 and 1/2 bath)
09-01-2015, 08:08 AM
#33
Re: 7.3 and Hills
Originally Posted by BajaSportsmobile
Originally Posted by TexGX
I am running 285/75/16, so not super large. I will look up rear gears.
I'll bet you already have 4.10 gears in your Quigley.
Does anyone here have 3.55 gears in their Quigley?
I've only seen a couple without 4.10s.
I have 3.55's :/ not very impressed with them. For towing anyways. For flat highway driving with no load they do great. But I don't do a lot of that.
09-01-2015, 10:34 AM
#34
Re: 7.3 and Hills
I confirmed I have 3.55 gears. This maybe the problem. Need to decide what next.
TexGX
TexGX
09-01-2015, 11:23 AM
#35
Re: 7.3 and Hills
TexGx: Again, I may be interested in your front differential 3.55 ring and pinion
09-01-2015, 02:46 PM
#36
Re: 7.3 and Hills
E350,
I will keep that in mind. I am thinking I will let it be now and address when or if I have a problem. It will be cooling off soon and be less of an issue. Not ready to spend that kind of money. I would rather take a trip.
TexGX
TexGX
09-01-2015, 07:05 PM
#37
Re: 7.3 and Hills
Be careful. If you are running into EGT issues on a stock tune, chances are your trans temps are getting up there too. #1 killer of diesel 4R100's.
09-01-2015, 10:23 PM
#38
Re: 7.3 and Hills
carringb,
It is funny you mentioned that. I noticed that after I removed my 4000's from in front of my grill and going to a light bar, my trans temps dropped. I have been watching both engine and transmission temps.
After talking to my local guy and someone's option I trust, I am going to keep what I have. The cost was getting too high for the gains. Maybe exhaust and a DP tuner for a start if anything.
TexGX
TexGX
09-01-2015, 11:24 PM
#39
Re: 7.3 and Hills
TexGX, was thinking - If you have access to a stock grill, that may be worth a shot to check temps vs using the billet grill.
09-01-2015, 11:35 PM
#40
Re: 7.3 and Hills
Most of the billet grills are just add ones to stock... So you could likely remove it and test pretty easily.
