Old 01-06-2020, 11:41 PM   #11
These guys are outside of Colorado Springs, CO. I have never worked with them but several F guys really liked what they did and how they did it.
https://turbologic.vistaprintdigital.com/
Old 01-08-2020, 09:10 AM   #12
allenl's Avatar
Thanks for the recommendation!
allenl is offline   Reply With Quote
Old 01-08-2020, 09:26 AM   #13
pod
pod's Avatar
Originally Posted by allenl View Post
I’d be very interested in that write-up! I’m comfortable that I could do the work, but it’s harder to find the time to tear into it. You spent 6 months on the engine rebuild alone?!
Hehe- time..... I hear ya. that’s why the project took so long, record rainfall, outdoor work location and two toddlers...I was able to at least roll in a few other mods/updates along the way, e.g. lots of “while you’re in there” type stuff.
Your post has inspired me to get crackin on that write up! Thx 👍🏻
Looking fwd to hearing about what you do to your rig.
-todd
pod is offline   Reply With Quote
Old 01-12-2020, 09:03 PM   #14
I agree with Herb broncohauler. I have a EGT gauge on mine and a Bully Dog variable chip. I can't use the second position on the chip. I will hit 1250 and get out of it. That only takes 30 yards of asphalt for it to happen! So intercooler is a must! Where are you going to put it maybe make a center console to keep the burritos warm because anywhere else will be big bucs! Some one here has done one and it's taken almost a year on the weekends!
Old 01-13-2020, 07:28 AM   #15
Thanks, I’ll check with him. I did get a shop recommendation from the guys over at CCV that I’m going to check out tomorrow.
Who did CCV recommend? Im in Denver and need a shop for the diesel vans
jchosler is offline   Reply With Quote
Old 01-14-2020, 05:22 AM   #16
bet on black's Avatar
Water or methanol injection helps a fair amount to reduce EGTs
'99 ford e350 - 7.3L 4x4
'10 ford f150 raptor scab
'53 buick special eight - the sled
bet on black is offline   Reply With Quote
Old 01-15-2020, 11:02 AM   #17
allenl's Avatar
Do you have this setup on your 7.3?
2000 Ford 7.3L EB Sportsmobile w/ UJOR
Old 01-15-2020, 11:03 AM   #18
allenl's Avatar
Performance Diesel in Loveland, CO
Old 01-17-2020, 08:50 AM   #19
REF
REF's Avatar
Send a message via MSN to REF
7.3L Performance Shop / Turbo Upgrade Question
A scanguage will keep tabs on EOT and TFT, otherwise a stand-alone EGT gauge as mentioned is necessary, I try not to go over 1200.
A tuner will be your best bet for gaining HP, which for most is plenty before reaching that threshold on stock injectors, unless you’re building a racer or show truck. You can get into throwing ridiculous amounts of cash at it when you reach that point, not to mention the prospect of piping in an inter cooler, which I’m not sure is the best bang for buck, you have to essentially reconfigure, relocate and custom fab almost everything in the engine bay. Someone on here is doing that....
I’d say make sure everything you’ve got is in tip top shape, including the turbo, if it needs a refresh, get a bearing rebuild kit if all other components are good and call it a day.
Check your turbo up pipes, if leaking, most likely they are, get the international bellowed up pipes, or to save a little, Doorman makes a decent knockoff set.
Run a bigger exhaust
Throw in a larger trans cooler, I went with a tru-cool, many put in the 6.0 cooler
Mag-hytec trans pan, helps keep it cool, larger capacity
I’ve had, along with many others here, a DP tuner. I can say we’re not all thrilled with it after some real world use. While it definitely woke the thing up, several that I’ve spoken to are experiencing the same symptoms of throttle input surging, which would be the converter locking/unlocking, causing more stress on components and premature wear, higher than expected EGT’s and higher than expected black smoke(rolling coal), essentially deeming the tuner useless for tow tunes and everyday use, even though they were specifically written for the vans! Jody claimed he hadn’t heard of that happening to anyone else.
I just had a John Woods transmission installed(picking back up today!) John used to use Jody’s (DP tuner) tuner for use with his transmissions, ran into the same issues we’re having and Jody was unwilling to work to change the tunes. John has been using PHP (power hungry performance) hydra chip with great success with none of the issues. John sent me a PHP chip along with his trans, looking forward to trying it out, I’ll report back after spending some time with it. Same deal, you can load various tunes, comes with a button selector to change tunes on the fly.
As far as diesel shops in the Denver/Boulder area, I had a hard time finding one that specializes and I tend to stay away from places that have a huge showroom with high overhead, trying to sell me everything they have on the shelf kind of place. The shop up in Loveland was ok, I used them for something, didn’t really get into performance stuff, I may recall they didn’t instill a bunch of my confidence. I’d stay well away from Lucky’s in Longmont, diesel specialists, talked a big game, had lots of trucks and several other SMB’s on the lot, crooks!
Diesel Services of northern Colorado in Johnstown got me back on the road fast, they deal mostly with fleet and I think big rigs, but were very accommodating.
Old 01-17-2020, 09:15 AM   #20
Yessir. Had it on this van and the last one too. I use the cooling most progressive kit.
Biggie
Berta
A Ramblin Van
truen
