'95 E350, 460 V8 - Starter relay location?
Hi all,
Noob here with a '96 E350 SMB, it has the 460 V8. It suddenly won't start (no click, won't turn over). Battery is good, all accessories work. I tried starting it in P and in N, same symptoms. I tried jiggling the shifter while turning the key, no difference. So I suspect the starter relay, the starter solenoid, and the neutral safety switch, in no particular order. (It clicked once, and it also caught/fired normally once, out of many attempts to start it.)
I reviewed my Chilton's carefully and I looked for the starter relay/solenoid on the fender wall where it "should" be according to the manual, but I don't see anything that looks like the relay/solenoid there. I also pulled the doghouse and looked along the inside walls of the dash/firewall, but I don't see anything there either.
Where is the starter relay/solenoid? Am I blind, or is it hidden behind/under something else? Any advice/suggestions/constructive criticism is welcome.
Thanks, and apologies if I am posting this in the wrong place -- as I said, noob here.
