Old 07-12-2010, 05:00 PM   #21
Re: Broken Axle
Originally Posted by RiverGypsy
That's just about as bad as an injector, since you have to remove the mounts and drop the motor to get the valve cover off a 6.0 in an E-350.
Unless it is the driver's side. Then you don't have to remove the motor mount.
I had one on each side replaced.
Old 07-13-2010, 10:27 AM   #22
John and Dana's Avatar
Re: Broken Axle
RiverGypsy,
You guys are really having a run of bad mechanical luck on this trip. I am sorry to hear about the multiple breakdowns. If you are headed though Seattle give me a shout and I will buy you a beer We also have a large yard where you can overnight if you need a spot.
Cheers
John
Old 07-13-2010, 11:20 AM   #23
RiverGypsy's Avatar
Re: Broken Axle
Originally Posted by John & Dana
RiverGypsy,
Cheers
John
Thanks, John!
If we come through Seattle, we will probably motor straight through (assuming the motor is still motoring). We're throwing a river festival in Whistler on the 24th, so ideally that will be the last stop on this trip before we head home and get to work paying off the credit card bills from this.
If it looks like we're stopping over in Seattle, I'll let you know.
Leland
RiverGypsy is offline   Reply With Quote
Old 07-13-2010, 09:42 PM   #24
Re: Broken Axle
You should be able to locate a full float sterling 10.5 at an auto salvage yard for anywhere from $300 - $800 which is less than the price of the cromo axles for the semi float stock dana 60. The sterling 10.5 is a workhorse used on F350 Super Duty trucks and I believe some of the F450 and F550's as well.
Anywhere I roam. Where I lay my head is home. Follow my 4x4 van build at https://4wheeldrivevan.com
4WheelDriveVan is offline   Reply With Quote
Old 07-18-2010, 11:15 PM   #25
Re: Broken Axle
F-450 uses a Dana 80. F-550 uses a Dana 135, according to this:
http://www.where-rv-now.com/Notes/Plent ... eltas.html
Current vehicle: 08' Power Wagon
Future vehicle,hopefully: SMB 4x4 RB 50, Purpose built for off-roading & camping, in style of course !!!
TwinStick is offline   Reply With Quote
Old 08-09-2010, 03:47 PM   #26
Re: Broken Axle
So the axle broke on our 2006 Ford while driving down the highway this morning. We didn't crash, bit it was tense there for a second. The shop says it broke due to wear and stress from the weight. We weigh about 10,500 - 11000 and certainly have driven off road a lot in the 4 years we've had the van. I was wondering if anyone has upgraded their rear axle to handle the extra weight and wear? Having broken an axle once, I don't ever want that to happen again...
Thanks-
Your experience convinced me to upgrade to a full floating axle. The semi-floater on an E350 is rated at 6340#, the full floater is rated at 7800#. I found one with the correct disc brakes and ABS - open 3.55 ratio. New Ring and Pinion and TrackLock $1500.
