Old 06-10-2007, 06:25 PM   #1
Send a message via Yahoo to jason_leaf_indymac
Diesel Exhaust Brake and Performance mods
Has anyone installed an exhaust brake to their Diesel SMB? If so, what did you pick and why? Also, has anyone added any power mods to their Diesel....exhaust, chip, turbo, guages....what brands and why?
Thanks!
jason_leaf_indymac is offline   Reply With Quote
Old 06-10-2007, 07:45 PM   #2
I spent a lot of time looking into this and found that none of the diesel performance shops I contacted work on the 6.0psd van. The engine layout, compartment and exhaust design are different, or so I was told. I'm happy with the pulling power and general performance and was always a bit wary about warranty issues. If you learn something different, please post an update.
Rob
2006 SMB 4x4, EB-51, 6.0psd
EMrider is offline   Reply With Quote
Old 06-12-2007, 04:01 AM   #3
I agree
Jason;
I agree with Rob on this one.
After our first extended expedition I watched the forums listed in my reply to your origional request for information.
What I noticed more often than not is that those who chose to modify their 6.0L's almost invaribly had major problems, including turbo, injector, headgasket, transmission and other failures.
Based on their experiences I took the safe course, and rather than mess with my engine and drivetrain, I added EGT and Trans Temp gauges.
On our second extended tour of the South and West these two gauges relieved any doubt that the E350SD, 6.0L PSTD, and the Torqueshift.
More gauges are in the future including coolant temp, fuel pressure, lube oil temp, Ampere, boost, power steering fluid temp, and more, not necessarily in that order.
Think long term durability.
CUL8R;
Ken Kill Sr.
2005 SMB RB15
6.0L PSTD
Torqueshift
Voyager Roof
:q6:
kenkillsr is offline   Reply With Quote
Old 06-14-2007, 01:36 AM   #4
JoeyNick's Avatar
I just reprogrammed mine with the LiveWire.
See this post:
http://sportsmobileforum.com/viewtopic.php?t=183
I'll be adding updates as I get more time behind the wheel with it. So far so good!
JoeyNick is offline   Reply With Quote
